odor of new trailer sickining
Last activity 2008-07-26 7:30 PM
23 replies, 11657 views
gaitedpickle
Reg. Mar 2008
Posted 2008-07-22 9:41 PM (#87978)
Subject: odor of new trailer sickining
New trailer,  burning our skin after about 30 minutes of being in the band new thing. How long does it take for the new odor to disipate?  Is there anything that can be done?
tom-tom
Reg. Feb 2008
Posted 2008-07-22 9:57 PM (#87981 - in reply to #87978)
Subject: RE: odor of new trailer sickining
100100100
I don't know if you are referring to the LQ area or the horse area but I had a similar problem when we bought a new one.  Even looking at new trailers the smell would make my eyes water especially in the horse are with the rubber floors and walls.  My solution was to plug up the A/C and run it to circulate the area.  We put in a plug and keep it plugged up.  I also put air fresheners (Glade makes one call Sunny Laundry that works well without making it smell like flowers) in the main area and the bathroom.  Changed them weekly until the new smell seemed to improve.  In the horse area I dropped all the windows; slide open butt windows and put down a bag of fresh pine shavings.  This didn't fix the strong rubber smell but did make it able to be tolerated and by the time we hauled the horses the first time they didn't mind going in at all.  Good Luck!
gaitedpickle
Reg. Mar 2008
Posted 2008-07-23 7:01 AM (#88008 - in reply to #87981)
how long did it take ? Week? two weeks?
tom-tom
Reg. Feb 2008
Posted 2008-07-23 8:35 AM (#88025 - in reply to #87978)
100100100
I was say between a week to 2 weeks.  I also opened the back doors and stud doors in the horse area if I knew it was not going to rain.  Any extra ventilation will help.  I didn't have any skin burning; but my eyes and nose could not allow me to stay in.  Running the a/c in the LQ really helped;  circulating air thru all of the new duct work seemed to remove the smell.  I still use my air freshener when not in use, but always keep it plugged up.  I don't know if putting baking soda would absorb any odors but might also be worth a try. Good Luck.
Posted 2008-07-23 8:44 AM (#88027 - in reply to #87978)
Was this a "glue" or more of a, "formadehyde" aroma?
Posted 2008-07-23 8:58 AM (#88029 - in reply to #87978)
If your trailer has some wood paneling and carpeting, it may contain formaldehyde. If you are susceptible to allergies, this will quickly bother you. This has been a problem with the FEMA trailers used after Katrina.
New carpeting has strong chemicals that take time to dissipate. The formaldehyde used in paneling may not do so quickly, and the smell may actually become more acute, when the trailer is stored sealed up in the hot weather.
Ventilate as much as possible, and use some box or window fans to keep the inside air moving when you're not using the trailer.
genebob
Reg. Nov 2007
Posted 2008-07-23 10:55 AM (#88052 - in reply to #87978)
Another thing that does help, belive it or not, is to spread a box of dryer sheets around the inside of the trailer. Not only do they absorb odors, but I put them in during winter storage to keep mice and other varmints out.
ponytammy
Posted 2008-07-23 12:55 PM (#88069 - in reply to #87978)
500100100252525
I've also used Damp rid in the bags. They absorb the moisture out of the air and along with it the odors. Charcoal works good too.
Terri
Posted 2008-07-23 2:14 PM (#88083 - in reply to #88052)
200050010010010025
Originally written by genebob on 2008-07-23 10:55 PM
We had a mouse in our camper this winter.  He/she used the dryer sheets to build it's nest.  But it did a nice job of hiding the mousey odors.
gabz
Posted 2008-07-23 3:33 PM (#88094 - in reply to #87978)
1000100100100252525
If there is a safe way to do so - burn some candles in the interior. It is the burning that burns off the smells. (For instance, put something down under the candles and then monitor the candles as you work around outside...  )
(burning candles also rid your house of cigarette smoke)
Another product is called Sweet PDZ - it's used as a stall freshner but is non-toxic and completely safe to touch and taste (if you are so inclined). Put a few butter tubs of this around - or spread in your carpeting. This is also excellent to use in the horse area with the shavings. It reduces the odor that might filter between the horses and the LQ.
Last trick is to use the Arm & Hammer carpet freshner powders... sprinkle all over the carpeting and leave it overnight. Vacuum. Repeat if necessary.
kentuckyrain
Reg. Apr 2008
Posted 2008-07-23 4:31 PM (#88105 - in reply to #88094)
Well since we are throwing out some ideas, here's mine. I have an Ionic Breeze air purifier in my home. I wonder if something like that would more quickly filter out the odors....
gaitedpickle
Reg. Mar 2008
Posted 2008-07-23 6:26 PM (#88115 - in reply to #88027)
Formaldehyde I think but am not sure.  The "Rubber " sheeting in the horse compartment also expands when hot.  Like wall paper coming off in the bathroom.
rick
Posted 2008-07-23 6:43 PM (#88116 - in reply to #87978)
This could take a while to rid LQ of smells, yours 2001 bought new always smells still when closed tight for a period of time, open windows and ventilate. Not smoking in your house also rids house of smoke smell.
gaitedpickle
Reg. Mar 2008
Posted 2008-07-23 8:12 PM (#88127 - in reply to #88027)
chemical or formadehyde
gaitedpickle
Reg. Mar 2008
Posted 2008-07-23 8:15 PM (#88128 - in reply to #88027)
chemical smell - you cn smell it from out side the traier in the parking lot
gaitedpickle
Reg. Mar 2008
Posted 2008-07-23 8:16 PM (#88129 - in reply to #88029)
What about returning it to yhe dealer???
gabz
Posted 2008-07-24 12:49 PM (#88181 - in reply to #88116)
1000100100100252525
Originally written by rick on 2008-07-23 7:43 PM
Yup. No smoking here except when 1 very close relative shows up for 3 days every 2 years.
gabz
Posted 2008-07-24 12:52 PM (#88182 - in reply to #88129)
1000100100100252525
Originally written by gaitedpickle on 2008-07-23 9:16 PM
Did you contact the dealer that sold it to you? Were the living quarters / interior done by that dealer or by another company?
The adhesives that are used are what cause the chemical smell and "burning"... Mobile Homes have long had this particular issue.
I used screws when I constructed my interior. No glue, but now I have the smell of Minwax Stain that I'm trying to get rid of (I just did that 3 days ago).... (with the rain, it's been hard to leave everything open for very long).
gaitedpickle
Reg. Mar 2008
Posted 2008-07-25 5:32 AM (#88234 - in reply to #88182)
dealer said it is cleaning chem the installers use - seems way too strong for that.  Thanks for all the suggestions.
Tuffyspop
Reg. Jul 2008
Posted 2008-07-25 6:09 PM (#88281 - in reply to #87978)
Open up two bags of charcoal lengthwise and leave them open in the trailer with it closed up to absorb odors when you have it parked.  Throw away the charcoal, don't use it for cooking.
Posted 2008-07-26 3:00 AM (#88302 - in reply to #88094)
Originally written by gabz on 2008-07-23 4:33 PM
Scented Candles
Inhaling scented candles for two hours may result in lead exposure that can threaten human health, according to a 2000 study published in 'The Science of the Total Environment,' conducted by the Department of Environmental Health Sciences at the University of Michigan. The study also noted that children may get exposed to lead in candle fumes on the floor, furniture and walls through their "hand-to-mouth" activity. A 2001 report from the Environmental Protection Agency (EPA) called "Candles and Incense as Potential Sources of Indoor Air Pollution"  found that scented candles are more likely to produce soot than unscented candles -- the particles of which can potentially penetrate the deepest areas of the lungs. The report also reviewed a study that found that certain candle emissions contained levels of these three chemicals that exceeded EPA-recommended thresholds.
gabz
Posted 2008-07-26 8:55 AM (#88305 - in reply to #88302)
1000100100100252525
Originally written by PaulChristenson on 2008-07-26 4:00 AM
Scented Candles
EWWW... Who knew?  So, when the  power goes out, UNscented are okay? I've never cared for many of the scented candles, personally - this gives me another reason to not use them.
The charcoal idea is a good one. I had forgotten that - A friend recommended that for when someone else's refrigerator got smelly when there was a lengthy power-outage.
Spooler
Reg. Aug 2006
Posted 2008-07-26 11:38 AM (#88314 - in reply to #87978)
50025
Best thing to do is air it out as stated.  My trailer was not as bad as some that I went in when I was shopping.  Open the doors, and run the A/C helps ten fold.
hounddog
Reg. Dec 2005
Posted 2008-07-26 7:30 PM (#88331 - in reply to #87978)
1000100100
Jump into a single or double wide house trailer.WOW.It will knock you down.Fema trailers had a HUGE problem with the smell.
