rough heat cycles
Last activity 2008-07-15 3:49 PM
12 replies, 6541 views
Terri
Posted 2008-07-15 12:45 AM (#87456)
Subject: rough heat cycles
200050010010010025
I know there are drugs out there to help mares who have heat problems.  Has anyone used any?
     My mare has been acting off the last few days and last night she didn't want to eat and had the runs.  After our March colic fiasco I ran her to the vet and as soon as we got there she started flipping her tail and talking with his stud.  She wasn't colicing again, she was in heat and spent all day (at home) laying around ocassionally looking at her belly.  She is doing better tonight and wanted to eat.  Hopefully her cramps are over with this go round.  She has always been a pissy mare while she is in heat but never this bad.
Any suggestions/ideas?  Aside from keeping her bred, which I don't want to do.......
Z71
Reg. Oct 2004
Posted 2008-07-15 7:15 AM (#87457 - in reply to #87456)
Subject: RE: rough heat cycles
Four years ago my mare was 10 when she started having seasonal cramps, at the time I didn't know such a thing even existed.  For 3 months every time she cycled, she would go off her feed and act like she was having colic, and we would end up at the vets for IV fluids because she would get dehydrated.  After about 3 days she would be OK.  I ended up getting her bred, and she has never had any more problems.  And I ended up with a very nice qt. horse filly.
jakey1
Reg. Dec 2003
Posted 2008-07-15 8:20 AM (#87460 - in reply to #87456)
There is a drug called Regumate that can be given to control excessive symptoms of a mare's heat cycle, however the drug is rather costly and should not be adminstered/handled by females of child bearing age.  I believe it may have to be administered via syringe, but it's been a while since I last saw it used, and can't quite remember.
In any event, you would have to get a vet to prescribe it.
Terri
Posted 2008-07-15 11:28 AM (#87470 - in reply to #87456)
200050010010010025
The vet mentioned the regumate, but this mare really, really, REALLY doesn't like being stuck.  When she coliced it took 2 tranqualizers and four people holding her head to get the IV in.
I was hoping someone would know of something that doesn't require needles for her.  I've already got 2 nice fillies out of her, she is 100% for fillies and color.  I don't want to breed her, I don't need anymore horses.
She is eating this morning but very slowly.
Edited by Terri 2008-07-15 11:32 AM
notfromtexas
Posted 2008-07-15 11:29 AM (#87471 - in reply to #87456)
100100252525
have used Regumate and it is effective, although also expensive and has to be handled VERY carefully.  Try Wendell's "moody mare" supplement, although I'm not sure who carries it, it has been several years since I had to deal with a mare!
Terri
Posted 2008-07-15 11:39 AM (#87472 - in reply to #87456)
200050010010010025
Valley vet has this.  I may have to bite the bullet and try it though.
http://www.valleyvet.com/ct_detail.html?pgguid=2e87bece-7b6a-11d5-a192-00b0d0204ae5
ponytammy
Posted 2008-07-15 1:12 PM (#87481 - in reply to #87456)
500100100252525
My friend had a mare that exhibited moody mare behaviors and always squirted near geldings.
After several months of awful behavior - she had blood tests to look at hormone levels and then she had a sonogram. The mare had a cyst on her ovary. She had two options - to spay her or remove the cyst which could come back at a later date. She choose removing the cyst. But a year later the same cyst problem occured.
Has your vet mentioned bloodwork to look at hormone levels? Might be best to just spay her and have a sane, happy horse.
terri s
Posted 2008-07-15 1:45 PM (#87486 - in reply to #87456)
500100100100
Might give Mare Magic a try. It's a topressing for feed, very cheap and available at Valley Vet. I had good luck with it for my mare. Has never heard of it but vet recommended it to me.
IcePonyGoddess
Reg. Nov 2006
Posted 2008-07-15 1:53 PM (#87487 - in reply to #87456)
500100100252525
Chat with your vet about putting a marble in her. Good luck!
KeepsakeFarm
Reg. Feb 2008
Posted 2008-07-15 3:18 PM (#87490 - in reply to #87456)
Regumate is given orally via syringe.  No needles.  But breeding or spaying might both be cheaper in the long run.
olehossgal
Reg. Dec 2003
Posted 2008-07-15 3:24 PM (#87492 - in reply to #87456)
  I used Regumate several different times on bred miniature mares (who may need it to help maintain a pregnancy THROUGHOUT the pregnancy, nevermind common veterinary thinking)...the dosage is by body weight, and was administered orally--just syringed it onto the back of the tongue daily( was always told to do it at the SAME TIME daily, because an even time span between doses was IMPORTANT!
   Of course, the amount given would be @ 4 times higher for a 'fullsized' mare, but don't see why you couldn't administer that orally too?? A 'catheter tip' syringe, or dose syringe, would work, I'd think....
  It is up to around $240 for a liter, by Rx, through several catalogs. Dosage is approx.(relying on memory!) 1 cc(= 1 ml) per 100 lbs. body weight, I think--orally.So, it IS expensive to give to a 'fullsized' mare--but is very effective.
  Correct about the care in handling; it contains progesterone and should NOT come in skin or other direct contact w/ a woman of childbearing age! A box of latex gloves would help....
  Good luck in dealing with this issue w/ your mare!
  Margo in NM
Terri
Posted 2008-07-15 3:47 PM (#87493 - in reply to #87456)
200050010010010025
My last vet told me that spaying a mare can give her a permantely "in heat" disposition.  He has one that was spayed that he used as a teaser for his stud.  She was a big B****.
I think I'll try the Mare Magic first.  Then if that doesn't help maybe the marble thing.
Terri
Posted 2008-07-15 3:49 PM (#87494 - in reply to #87490)
200050010010010025
I would love to breed her to Cool Hand Luke.  But I've got to save my pennies first.
