grabbing brakes
Last activity 2008-07-14 6:54 AM
5 replies, 4312 views
2008horsesrus
Reg. Jul 2008
Posted 2008-07-13 6:40 PM (#87397)
Subject: grabbing brakes
hi,
my trailer brakes have been just fine and now they "grab and lock for a while, then unlock, the lock etc as I am driving down the rode. I have had to disconnect my brakes so I can drive. Any thoughts to the cause and a fix??
chadsalt
Posted 2008-07-13 7:19 PM (#87399 - in reply to #87397)
Subject: RE: grabbing brakes
1000100100100100
Brake controller?
2008horsesrus
Reg. Jul 2008
Posted 2008-07-13 8:18 PM (#87403 - in reply to #87397)
yes I have one and I have adjusted the setting, pushed the button to reset etc.
chadsalt
Posted 2008-07-13 9:43 PM (#87409 - in reply to #87397)
1000100100100100
What kind? How old?  Something has to be telling the brakes to come on, usually is the brake controller............although it could be a short in the plug?
Posted 2008-07-13 10:30 PM (#87413 - in reply to #87397)
Like Chad said, something has to be activating the brakes. If it isn't an errant controller, it has to be another source of voltage going to the brake wiring.
You can try disconnecting the activating wire from the controller to the trailer. If the trouble persists, the problem probably isn't the controller, rather it's the wiring. If the problem goes away, it's probably the controller that is at fault.
2008horsesrus
Reg. Jul 2008
Posted 2008-07-14 6:54 AM (#87420 - in reply to #87397)
okay, thanks I'll check the controller. Can't afford a "trailer shop" visit it fix a simple problem. I'll google for instructions. Thanks again
