Any creative ideas for nicely finishing the "curve" in a trailer
Last activity 2008-07-25 1:25 PM
14 replies, 7652 views
eclipse
Posted 2008-07-12 9:14 PM (#87361)
Subject: Any creative ideas for nicely finishing the "curve" in a trailer
I spent all day putting up foamboard. Tomorrow I can start on paneling. But no matter how hard I brainstormed and played around with materials today, I did not come up with a good idea for finishing the curve between the walls and ceiling.
Anyone want to share their brilliant ideas???
cowpony01
Reg. Mar 2006
Posted 2008-07-12 9:23 PM (#87363 - in reply to #87361)
Subject: RE: Any creative ideas for nicely finishing the "curve" in a trailer
100100100100252525
I have seen alot of folks pics on here that have, and I wish I would of done it this way, is to not curve it but do it as a slant, and trim it out (the top and bottom seams). I hope that makes sense or I explained it right......
Turfa
Posted 2008-07-13 8:37 AM (#87371 - in reply to #87361)
I did mine on a slant which left me room for wires and antena.  See attached picture.  One side trimmed the other still has the insulation showing.
Turfa
Posted 2008-07-13 10:48 AM (#87377 - in reply to #87361)
 We have two different brands of trailers with interiors built by LQ conversion companies. They both have the ceiling to wall transitions as  bevels (slant) instead of a curve. This area is treated as a large crown molding. The small space it provides would be an ideal space to provide for wiring chases. It has an attractive appearance and is easier to install than a curved panel. Turfa's picture shows how attractively it can be constructed.
nd deb
Reg. Apr 2004
Posted 2008-07-13 11:39 AM (#87379 - in reply to #87361)
We just put a suspended ceiling in ours so it covered it up.
eclipse
Posted 2008-07-14 7:01 AM (#87421 - in reply to #87361)
Okay, maybe what I need to ask are very specific questions about mounting this piece. I had thought to get a thin piece of board about 6 inches wide and put a pretty horse wallpaper border on it. I have some ideas for attaching it to the wall portion, as that is wooden paneling. But how do I attach this at the ceiling portion? My ceiling is foamboard covered with vinyl.
Posted 2008-07-14 10:34 AM (#87430 - in reply to #87421)
Originally written by eclipse on 2008-07-14 8:01 AM
You can use a quick tack polyurethane construction adhesive. Tape it in place with painter's grade masking tape until the glue solidifies.
cowpony01
Reg. Mar 2006
Posted 2008-07-14 3:09 PM (#87442 - in reply to #87361)
100100100100252525
I've seen western wallpaper motif around the bends like you wanna do, and it looks good. Yup, super tough glue until it dries, like Gard mentioned....
imeasystreet
Reg. Apr 2008
Posted 2008-07-17 8:26 AM (#87596 - in reply to #87361)
I used 1/8" tempered masonite and covered that with thin 4'x8' fiberglass sheets. In the nose I had to make forms to glue 2 pieces of tempered masonite together and did board and batten.
gabz
Posted 2008-07-17 11:57 AM (#87613 - in reply to #87596)
1000100100100252525
I'm considering this product - it appears to be long slats of wood, joined together somehow. Almost looks like the material used in rolltop desks.
http://www.polewrap.com/
So far as mounting it, you might need to add some small "tabs" at the top of you siding (behind), or overlap and use electric staple gun.
Barfly
Reg. Jun 2008
Posted 2008-07-19 12:40 AM (#87717 - in reply to #87361)
Hi Eclipse
I am just finishing off my LQ and have decided to finish the corner off with sisal rope. I do not have much of a gap (if any) at the intersection, but thought it would look quite horsey to put the sisal rope around all the intersections. It is simple to fix - just a staple gun and - hey presto its done - and it is origional...
Cheers for now
eclipse
Posted 2008-07-19 9:24 PM (#87738 - in reply to #87361)
Barfly--I like your creativity, although my curve is a lot wider than rope. I will probably do the wall paper design on a 6 inch piece of board and put it up there at an angle. But I really love the pole wrap idea. I will look around here and see if such a thing is available!
renee92355
Reg. Feb 2008
Posted 2008-07-20 10:15 AM (#87746 - in reply to #87361)
OK, I had the same question last summer when I redid my LQ.  We actually took a bendable molding and tried to heat it to curve, but it was still too stiff. so we cut the molding into 4" sections and just pieced them together like that, it came out OK.The moulding we had had a dark woodgrain effect and it went well as a topper to my beadboard. Renee
gabz
Posted 2008-07-24 5:28 PM (#88205 - in reply to #87738)
1000100100100252525
Home Depot advertises the pole wrap. I saw it at my local store.
I can't wait to tackle that next. After the ladder / carpeting.
zpriverrider
Reg. Jul 2008
Posted 2008-07-25 1:25 PM (#88268 - in reply to #87361)
I just put LQ in my 1991 Cornpro and had trouble finding something to finish out my ceiling corners. I used pipe insulation. The round stuff that has a slit in it to fit over pipes. I used the size for 1/2 inch pipe. The stuff is made out of foam. I painted it white and glued it up with liquid nails. It looks great and at a great price. It is able to follow the ceiling line on the round edges of the roof and also it will turn to follow the wall on the slant wall.
