Raising trailer roof
Last activity 2008-07-20 5:39 PM
5 replies, 7863 views
adeberti
Reg. May 2007
Posted 2008-07-10 6:33 PM (#87236)
Subject: Raising trailer roof
So we have a 2006 Circle J 4h slant BP with an inside height of 7'4", the problem is that my horse (3yrs shire) already touches the roof with his hears and he is probably going to grow another hand (17h to 18h, as his parents were roughly that size)How economical would it be to take off the roof (fiberglass) and have a shop weld and extra 3-4 inches on top and re-attach the roof? It's not a top priority since he generally travels with his head down in two slant compartments made into one.The trailer is all aluminum if it makes a differencethanks
Posted 2008-07-10 6:53 PM (#87239 - in reply to #87236)
Subject: RE: Raising trailer roof
I believe I would swap for an 8' tall trailer... Or maybe one like this!!!...
http://www.horsetrailerworld.com/home/trailerdetail.asp?ID=164544
Posted 2008-07-10 8:29 PM (#87245 - in reply to #87236)
To accomplish what you suggest is quite possible, especially in CA where many fabricators make good livings by modifying vehicles. Because it will be a complex undertaking, the costs involved will be substantial.
The fiberglass roof is supported by metal supporting structures. The additional height added to the walls, will have to be reinforced to support these braces. The fiberglass roof is a singular one piece design, and will have to be removed and replaced intact. Have you considered how to treat the additional heights above the doors?
With a horse growing as large as your's potential, it might be advised to add an additional height to reach 8' instead of 7 1/2'+.
This should not be a first time job offered to someone who thinks he can do the work. This will take skill, adequate tooling and facilities to properly complete. If it is done incorrectly, your trailer will be ruined.
I would seriously consider the purchase of another trailer. This would be a major fabrication and expense, and may not work out well.
brushycreekranch
Reg. Jun 2006
Posted 2008-07-11 7:34 AM (#87261 - in reply to #87236)
500100100100100
I have a close friend that has a stock trailer that the roof was raised what appears to be about 8".  Just by looking at it, you immediately know where they cut it off, put in the addition height than sat the top back on it. I would say that if you can't do it without it looking like it came from the factory that way, then sell it and buy exactly what you want. Butchering it only will decrease its value to others.
Tresvolte
Reg. Feb 2008
Posted 2008-07-11 8:13 AM (#87265 - in reply to #87236)
It is possible, but I have a feeling it would be less expensive in the long run to trade it in for a taller trailer that more meets your needs.
DD_TrailerMan
Reg. Jul 2008
Posted 2008-07-20 5:39 PM (#87775 - in reply to #87236)
Would not recommend adding to the roof.  I would think that we hurt resale value and would not be cost efficient.  Also beware, some people that think they have an 8 tall trailer is actually only 7'6".  I have only seen a few true 8 tall trailers.
