Trailer pulling down on truck
Last activity 2008-07-10 12:16 PM
5 replies, 4602 views
luckeys71
Reg. Dec 2007
Posted 2008-07-07 5:20 PM (#87011)
Subject: Trailer pulling down on truck
I am still quite new to this trailering thing, in fact, although I have now pulled my trailer many miles to the house and back to the barn (for repair work) and off to have professional work done on it, I have only had a horse in 2 times, once for exactly 1 mile and just recently a quick trip around the barn.  Anyway, I have a receiver hitch on my Ram 1500 and pull a simple steel 2h BP, no dreesing room or anything.  It is fine on smooth pavement, but when the going gets rough, it feels like the trailer tugs down on the truck.  I have the ball in the drop position and the trailer (unloaded) looks perfectly level.  Wondering if I just need to put the ball in the rise position and raise it up a little.  I would just do the quick experiment, however, I had a Maintentance guy at work put the ball on for me and I can't get the dang thing to budge at all, as far as getting it off.  Both pieces are new, too!  To get the rise, I guess I'll have to go out and get another receiver bar and ball, so wanted to see if that was my problem, first, before tossing out another $30, because I could put probably 1/4 tank of gas in my truck for that!  Tires on truck and trailer are fully inflated.
Terri
Posted 2008-07-07 5:33 PM (#87013 - in reply to #87011)
Subject: RE: Trailer pulling down on truck
200050010010010025
     What do you mean by pulling down?  If the trailer is jerking on a rough road you may just need to slow down.  There can also be some "jerkyness" depending on how much play there is with the reciever bar.
     The trailer should be a bit "nose up" when empty that way it will be almost level when the horses/tack/feed are loaded.  Having a slight tilt (rear lower) will also help with run off when the horse pees.
califhorseman
Reg. Feb 2008
Posted 2008-07-07 9:25 PM (#87031 - in reply to #87011)
If you think the receiver is to low use a bench vise and a correct wrench to break the ball free. Once you have done this flip the receiver over and remount the ball. This will give you the few inches lift that you might need.
BOL
Jeff
The OEM Parts Store
Reg. Jul 2008
Posted 2008-07-10 12:47 AM (#87183 - in reply to #87011)
I would have to agree with all of the above. And why is your reciever stuck? That does not sound like a good fit. It should slide easy into the ball mount. I am not sure what type of trailer ball mount you have, but if you want to save a few pounds, try going aluminum. They are super light weight and just as tough. We carry a bunch of different Trailer Ball Mounts. You can at least get an idea and fix the issue with yours. If turning over the ball doesn't work, I would want to know what brand trailer do you have. You could always move the axle(s). But that is a bit of work and would only recommend a professional doing something like that. And you might check the springs on your truck to make sure they are still good to go. Good luck!!
Jason
Edited by The OEM Parts Store 2008-07-10 12:48 AM
luckeys71
Reg. Dec 2007
Posted 2008-07-10 12:01 PM (#87211 - in reply to #87011)
It is just the ball that is permanently attached to the receiver bar.  The Maintenance guy at work who put it on for me, put it on EXTRA tight.  He said it was on to stay and he wasn't kidding.  No problem with that thing loosening up.  I was just trying to figure out if that was the problem before investing in a new bar and ball.  The ones I already have are almost new.  The truck doesn't bounce, it just feels like someone has literally grabbed the ahold of the back of the truck and tugged it down when it hits a bump.
chadsalt
Posted 2008-07-10 12:16 PM (#87212 - in reply to #87011)
1000100100100100
How are your shocks?
