How to create a 3 inch hole in steel trailer?
Last activity 2008-07-24 11:50 PM
15 replies, 6554 views
daafy
Reg. Apr 2006
Posted 2008-07-06 1:42 PM (#86927)
Subject: How to create a 3 inch hole in steel trailer?
I have a vent that I'd like to install in the side of my steel trailer.  The vent requires a 3 inch opening for installation.  Any suggestions on how to create a 3 inch hole in 1/4 inch steel?
It was suggested that I use a cutting torch but I'm afraid it may be catch the inside insulation and paneling on fire.
Thanks.
jd&ez
Posted 2008-07-06 1:46 PM (#86928 - in reply to #86927)
Subject: RE: How to create a 3 inch hole in steel trailer?
Go to the hardware store and get a 3" hole saw bit.
Terri
Posted 2008-07-06 2:06 PM (#86932 - in reply to #86927)
200050010010010025
Round hole?  Or square/rectangle?  If it is round you can get a steel cutting hole saw, if it is straight lines you can get a grinding blade for a skill saw or a metal cutting blade for a reciprocating saw.  Depending on the steel, you may need more than one blade.
Posted 2008-07-06 7:27 PM (#86952 - in reply to #86927)
Round... hole saw
Square ... Drill 4 holes at each corner and use a saw to connect the dots.  File or grind the edges smooth.  Leaves a stress free hole that won't propagate cracks.
HWBar
Reg. Nov 2005
Posted 2008-07-07 5:18 AM (#86963 - in reply to #86927)
1000100100252525
Originally written by daafy on 2008-07-06 1:42 PM
That would be a very, very heavy trailer.
Posted 2008-07-07 8:19 AM (#86969 - in reply to #86963)
Originally written by HWBar on 2008-07-07 4:18 AM
 I didn't catch the thickness in the OP .... Beware of cutting a large hole in a structural member...  You could weaken the trailer to collapse
daafy
Reg. Apr 2006
Posted 2008-07-18 1:19 AM (#87669 - in reply to #86927)
The hole needs to be round and I just guessed at the thickness.  Come to think of it, a 1/4 inch does sound thick...the trailer is made of standard steel.
Thanks to all for the advice.
Tx. Vaquero
Reg. Jun 2006
Posted 2008-07-18 6:58 AM (#87671 - in reply to #86927)
a .50 cal. at 25 yds. will do the trick
gabz
Posted 2008-07-18 6:05 PM (#87703 - in reply to #86927)
1000100100100252525
I suggest making your center pilot hole first, the using the hole saw. Center the hole saw in your pilot hole. Use a heavy-duty drill.
Use a bottle of oil - those little bottles with the tiny squirt top and apply oil frequently to the drill bit AFTER you get it started. The oil will reduce the friction and help the bit cut through the steel.
Or...like me, take it to an RV place and let them do it and install the cover/vent. : )
Posted 2008-07-19 7:50 PM (#87733 - in reply to #87703)
Originally written by gabz on 2008-07-18 7:05 PM
Hole saws are connected to pilot drill bit via an arbor...
DD_TrailerMan
Reg. Jul 2008
Posted 2008-07-20 5:02 PM (#87771 - in reply to #86927)
I think the best way would be to use a plasma cutter.  Most welding shops should have one.  It will cut 1/4 no problem and will do minimal damage to paint.  Plasma doesn't get as hot as a torch.  Be ware of cutting structural members.
gabz
Posted 2008-07-23 3:21 PM (#88092 - in reply to #87733)
1000100100100252525
Originally written by PaulChristenson on 2008-07-19 8:50 PM
Yes - BUT - if you are trying to control a hole saw on sheet metal - they tend to skitter around. It's much easier to drill a 1/4 inch or so hole, then use that to anchor the hole saw.  It also helps tremendously with the accuracy of placement.
Posted 2008-07-23 10:17 PM (#88145 - in reply to #88092)
Originally written by gabz on 2008-07-23 4:21 PM
Actually you mark the metal by using a center punch.
gabz
Posted 2008-07-24 12:59 PM (#88183 - in reply to #86927)
1000100100100252525
If you own one. : )  I have a very well-outfitted shop for the most part, but steel working tools are in limited supply.
Same as with a plasma cutter - oh yeah... like everyone's got one of THOSE in their shop. NOT.
I have found, over the years, that when people ask questions that appear to have obvious answers - it's because they do not have the experience that many other people do - hence, I find it's easier to give as much information as possible.
Now, if the others who mentioned using a hole saw had said "First get a center punch to mark the center of your hole ...." then I probably wouldn't have said anything. I only know that when I tried to do something like that (withOUT center drilling or punching)... I had a heck of a time. Hence, I took my steel trailer to an RV place and had them cut the hole and install the device. The technician then explained to me about using a drill first. I already knew about applying oil to make the cut go better. I have been using the 3-in-oil everyplace I have drilled into the frame - which is thicker steel than the panels.
    OKAY?
Terri
Posted 2008-07-24 3:46 PM (#88197 - in reply to #88183)
200050010010010025
If you don't have a center punch you can use a phillips head screw driver.  One with a small head.  Putting masking tape over the "pilot" area will also help with the bit slipping around.
Posted 2008-07-24 11:50 PM (#88230 - in reply to #88183)
Originally written by gabz on 2008-07-24 1:59 PM
    OKAY?
I guess when you run a farm you have equipment that you just ASSUME......other people have...
Actually having someone else do something, like drilling holes in things that are important to you makes sense...because if THEY screw up, you can SUE THEM to make it right...
Versus the rest of us that chalk an error up to experience...which explains how we come to know quite a few things...lots of errors...
