preferences on AC units?
Last activity 2008-07-07 11:39 AM
10 replies, 7429 views
ksgirl
Posted 2008-07-04 8:53 AM (#86857)
Subject: preferences on AC units?
Getting ready to put an AC unit in our small 4' short wall living quarters.
Anybody have any suggestions, dos, don't or preferences of what brand, how many BTU'S and wether or not to get a heat strip?
We live in TX we do travel some up north, as we have lots of family in KS.
Thanks!
Lena's Mom
Reg. Dec 2006
Posted 2008-07-04 9:00 AM (#86858 - in reply to #86857)
Subject: RE: preferences on AC units?
I live in Texas as well and I can tell you that a heat strip is of no use.  Get a small ceramic heater from Wal-Mart and you will be cozy warm.  I use one in my 6' SW and it is fine.  can't help you on the AC.  Whatever they put in mine when I bought it works well even in Texas.  Just the standard roof air by Carrier, I think.
ksgirl
Posted 2008-07-04 11:00 AM (#86859 - in reply to #86857)
thanks for your reply.
we are looking at a carrier, either 13,500 or 15,000 units.
The only reason we were looking at the heat strip is because we do make those trips north, but maybe we will get a small heater to keep with us.
Posted 2008-07-04 11:09 AM (#86860 - in reply to #86857)
I agree the heat strips are worthless.   Don't waste your money.
How big a generator do you have?  Make sure it will run what ever A/C you buy.  The two LQ trailers I have had both had 18,500 btu units.  So I figured they were pretty much the standard size for horse trailer LQ.
I never use my A/C camping, since I primative camp in the mountains and it's usually pretty cool there. I never go to fairgrounds or horse show, so there is no sweltering in a parking lot for me. The only time I turn on the A/C is at home when I am loading or unpacking the trailer for trip. And then it seem I can't get enough cold air. But then again we are opening and closing the door a lot while we clean out the trailer. So my advice is go the bigger unit.
KeepsakeFarm
Reg. Feb 2008
Posted 2008-07-04 11:25 AM (#86863 - in reply to #86857)
I was in a friend's trailer, that was outfitted at the Integrity dealer in Texas if that matters, and her AC fans blow out from a circular opening so less air is forced right out onto the bed area.  I would like that at night and I bet it keeps the trailer a more uniform temperature.  My AC has more of a square area for the cold air to either blow onto the bed or towards the slant wall.  Does that make sense?
And I used my heat strip and it takes the edge off the cold, which is all I needed that evening but will take a plug in if it ever is cold when I use the trailer.
Sheryl
Posted 2008-07-04 2:01 PM (#86869 - in reply to #86857)
Well, I must have a really good heat strip because I've never needed to use additional heat.  I live and camp in Tennessee so it does get really cold here.  My sw is 4' and well insulated so that probably does make a difference.  Might not be as effective in a larger trailer.  I wish my a/c had a better way to divert the air because it does bother me to have it blowing on me in the bed.  Some of the units have more flexibility than mine and I wish I had investigated them a little better before I bought mine.
ggrimm01
Reg. Aug 2005
Posted 2008-07-04 4:48 PM (#86878 - in reply to #86857)
All AC units are good.  We have a carrier and I just spent about a total time of 8 Hrs bending the fins back in place because of a hail storm.  I would look a several units that have covers over the fins.
Posted 2008-07-06 7:32 PM (#86953 - in reply to #86857)
I chose a Carrier unit without a heat strip.  The ceramic heater is much less noisy that the A/C circulating fan.
Added benefit, when the hook-up allows, I'll use two heaters.
Sheryl
Posted 2008-07-06 9:53 PM (#86959 - in reply to #86857)
The fan noise is a benefit to me as "white noise" which drowns out any campground noise and lets me sleep.  Before, when tent camping, I've had everything from a litter of newborn puppies, to mules, to drunks keeping me awake!!!
Dunoir
Posted 2008-07-07 10:30 AM (#86978 - in reply to #86857)
50010025
Another benefit with the ceraminc heaters is you can adjust the temp so it will turn off and on, but they are very quiet.  They also don't blow on you like the AC units.
I did find a control on the AC unit where the vents will move up & down, so it's not a constant steady blow of cold air on you.
puglady
Reg. Jan 2008
Posted 2008-07-07 11:39 AM (#86989 - in reply to #86857)
Whats the average lifespan of an AC unit?
Because they sit on top in the hot sun, do they deteriorate over time if you do not keep your trailer in an RV garage, barn shed or shelter?
