Hot Water tank
Last activity 2008-07-01 7:50 AM
9 replies, 4899 views
2bitnag
Reg. May 2008
Posted 2008-06-29 11:50 AM (#86613)
Subject: Hot Water tank
Okay trailer gurus, my hot water tank (propane) will light but not stay lit.  Thermocoupler or what?
Thanks
Posted 2008-06-29 12:30 PM (#86616 - in reply to #86613)
Subject: RE: Hot Water tank
Not enough gas pressure? Bad regulator? Bad thermocouple? Pinched gas line? Empty tank? Plugged line? Bugs like to live in the small gas orfices and plug things up. Disconnect the line and blow it out with air to see if its clear.
HWBar
Reg. Nov 2005
Posted 2008-06-29 7:44 PM (#86654 - in reply to #86613)
1000100100252525
9 out of 10 times it will be the thermocoupler, it's a cheap fix, you should never blow air backwards through your gas system.
rockyrider
Reg. Jun 2004
Posted 2008-06-30 1:35 AM (#86667 - in reply to #86613)
100100100
Where can you get replacement annode rod? Mine is almost worn thru.
HWBar
Reg. Nov 2005
Posted 2008-06-30 4:38 AM (#86669 - in reply to #86667)
1000100100252525
Originally written by rockyrider on 2008-06-30 1:35 AM
If it's an Atwood or Suburban Water heater they should be available at any RV store, or on Ebay. There are a number of RV stores that have set up stores on E-bay. I have dealt with a few of them and the service is outstanding.
Posted 2008-06-30 8:42 AM (#86676 - in reply to #86667)
Originally written by rockyrider on 2008-06-30 2:35 AM
You can purchase annodes at plumbing stores, Lowes and Home Depot. They sell them by standard sizes that include most RV applications.
DaveM
Reg. Sep 2003
Posted 2008-06-30 10:31 AM (#86678 - in reply to #86676)
It's nice to see you two partner up and help this fellow.  Thanks.
HWBar
Reg. Nov 2005
Posted 2008-06-30 5:31 PM (#86688 - in reply to #86613)
1000100100252525
I'm always here to help a guy out, if I know something about it.
If I don't know, I stay out of it.
Posted 2008-06-30 9:01 PM (#86700 - in reply to #86613)
You can blow out any gas line by first disconnecting each end. Then apply pressure to the appliance end blowing towards the gas pressure source. If you were to blow the other way, any lodged substance could be more firmly emplaced.
You shouldn't pressurize any system with a connected valve or diaphragm type of regulator. They can be damaged by any excessive pressure. If the line you are purging is connected to multiple appliances, it is necessary to isolate them to avoid damaging them as well.
2bitnag
Reg. May 2008
Posted 2008-07-01 7:50 AM (#86714 - in reply to #86613)
Thanks guys!  Guess how I am spending my Canada Day holiday  Bought a new thermocoupler and will go from there.  You guys have a good July 4th!
