generator pros and cons anyone?
Last activity 2008-05-22 3:03 PM
3 replies, 4780 views
belleabres
Posted 2008-05-19 8:02 PM (#84249)
Subject: generator pros and cons anyone?
looking for a new generator, propane, quiet, dependable, not so big as to use a ton of fuel ,big enough to do the job, like to put it in the hayrack on top of trailer. anyone have any ideas?  thanks!
flyinghfarm
Posted 2008-05-19 8:53 PM (#84258 - in reply to #84249)
Subject: RE: generator pros and cons anyone?
1000100100
Ours is very quiet, runs AC and microwave at the same time.... it is an Onan 4000 MicroQuiet (but in the rear tackroom with 2 vents, in a custom insulated box, with it's own fuel tank in a manger)
http://www.coolhorse.com/trailers/generators.html
landsalmon2
Reg. Mar 2007
Posted 2008-05-22 2:07 PM (#84482 - in reply to #84249)
We have a 3000 watt Yamaha invertor generator. It is very quiet and will pretty much run everything. I never run it for very long when we dry camp where other campers are close by .
Posted 2008-05-22 3:03 PM (#84485 - in reply to #84249)
Seeing some of these up in the hay rack roof area on some of the larger trailers. 8kw, self contained unit weighing 340#.
http://www.generac.com/Products/Residential/AirCooled/8KW.aspx
http://www.generac.com/publicPDFs/0176720SBY.pdf
You'll find these on the roof of some Twister LQ trailers...  http://www.guardiangenerators.com/Products/Recreation/Quietpact/QUIETPACT40.aspx
Here's one that says it has a 4.0 ONAN.... Looks like a Generac Guardian RV to me.. http://www.horsetrailerworld.com/home/trailerdetail.asp?ID=156627
Edited by retento 2008-05-22 3:17 PM
