Lots of ticks
Last activity 2008-05-22 12:04 AM
19 replies, 8818 views
Lea Anne
Reg. Mar 2005
Posted 2008-05-14 9:37 PM (#83966)
Subject: Lots of ticks
Can some one tell me.....isn't it okay to put Seven dust in the horses manes to prevent ticks?  I haven't done it yet cause I wasn't sure if I was remembering correctly.  My guys have a lot of them right now and it's been too cool to bathe them yet.
Thanks.
bbsmfg3
Reg. Dec 2006
Posted 2008-05-14 10:08 PM (#83967 - in reply to #83966)
Subject: RE: Lots of ticks
I've seen Seven used without a problem and also with problems. Some horses have a reaction to Seven. Why not use something that is approved for horses.
Farnam's RePel-X does a good job, and lasts longer than Seven.
Posted 2008-05-15 12:36 AM (#83975 - in reply to #83966)
Ticks
Ticks are a dangerous parasite because they carry a large number of diseases of humans and animals, including horses. Once premises are infested with ticks, they will become an increasingly severe problem. Therefore prompt action should be taken to destroy ticks when they are first found on a horse. The owner will usually not see the larval forms of the ticks, but rather the engorged tick attached to the skin.
When only occasional ticks are seen, the simplest way of handling them is to squirt them with a tick bomb (such as those made for dogs) or dab them with a little screwworm smear. They will then die and fall off, in time. Applying lighted cigarettes or gasoline is unnecessary and unsafe.
Ear ticks
These are especially troublesome in horses because they live deep down in the ear, causing great discomfort to the horse. Horses with ear ticks will shake their heads from side to side, become ear-shy and are hard to bridle.
These ticks are easily killed by instilling in the ear a mixture of mineral oil with a little lindane screwworm smear mixed in. Commercial mixtures are available, too. It is necessary to restrain the horse with a twitch while doing it or he will not allow the medication to be left in the ear and will immediately shake it out.
If the ears have been infested for a long time, there might be considerable debris and a secondary infection present, necessitating veterinarian attention.
Control/prevention
Tick control is the key to minimization of tick-borne diseases. The tick population can be kept to a minimum by maintaining fields and paddocks in a closely mowed state, and horses should be kept out of wooded or overgrown areas.
Routine examinations should be performed on the horses. The primary sites of tick infestation are the ears, mane, tail, and under the tail, around the anus and vulva. In a tropical country, I have seen in excess of 100 ticks in these latter areas on a single mare.
Manually removing the ticks is tedious and may well not be fully appreciated by the horse, especially in the anal-vulvar area, so the proper use of parasiticides or pesticides is the treatment of choice. Remember: a tick is not an insect it is an arachnid therefore, most insecticides are of no help. Pyrethrins and permethrins are effective, but it is essential to strictly follow the instructions on the label.
The life cycle of some ticks is two or three years, so if you do choose to
remove them manually (which you may well do in the case of only a few ticks), dont just flick them onto the ground or the stall floor. Do something to kill them. The brick-and-hammer method is especially effective, but much easier and more convenient is the maintenance of a small bucket (or coffee can) of water, into which you can drop the removed ticks. They are notoriously poor swimmers.
j&j
Reg. Oct 2005
Posted 2008-05-15 6:25 AM (#83977 - in reply to #83966)
I use any of the available horse "spot-on" products and they work for 2 weeks against ticks. One horse who is light colored will have a few on him, but they are always dead. The other horse never has ticks. We are in MO where ticks are rampant.
Here is one example for sale
http://www.jeffersequine.com/ssc/product.asp?CID=1&pf_id=0026714
j&j
Edited by j&j 2008-05-15 6:31 AM
lesliemal
Reg. Sep 2007
Posted 2008-05-15 8:39 AM (#83987 - in reply to #83966)
I got an email a while back giving a way of removing ticks that are attached. Take a cotton ball dipped in liquid soap and cover the tick for 15 to 30 seconds. I was told this would make the tick "back out" and then just remove. I have not tried it yet. I know ideally you would want to prevent the tick from attaching in the first place but I will try this trick the next time I find a tick attached to me, my horses or my dogs.
crowleysridgegirl
Reg. Apr 2005
Posted 2008-05-15 9:09 AM (#83991 - in reply to #83987)
2000500100
We fortunately don't have ticks in the region where we live (mosquitos ran them all off) but when we ride in MO or in the hills,they are BAD.I spray my horse's legs with a high concentnration of permethrin that I find in the available horse sprays,and I spray my shoes and pants legs with Repel.It can't be applied to the skin,but it works well.Also on my skin just in case,I have found that the Avon Bug Guard works REALLY well.
Z71
Reg. Oct 2004
Posted 2008-05-15 10:48 AM (#83997 - in reply to #83966)
From March to Oct. I add a 1/2 cup of apple cider vinegar to my horses feed and theyvery seldom have ticks now.
calamityj
Reg. Jun 2005
Posted 2008-05-15 1:07 PM (#84015 - in reply to #83966)
500100252525
Hey ya'll... We use "Buzz-off". I think we got it at our vet's office. It is a thick liquid that you run a line from the forelock to the wither- then, a line from the rump to the tail-dock, and down the front legs and back legs... i have never seen anything that works as well. We rode with some people who sprayed their horses and returned that evening to find NO TICKS on ours.. the people's horses were absolutely infested with both large and tiny ticks. ( We also spray our clothes,boots, and caps or hats with permanone)
terri s
Posted 2008-05-15 3:32 PM (#84022 - in reply to #83966)
500100100100
If you can find PrevenTic, a dog flea and tick spray, it works about the best of anything I've tried. Vet told me about it, I spray the underside of the mane and dock of the tail and stay tick-free for weeks. Adams Flea and Tick works well also.
barntoys4mom
Reg. May 2007
Posted 2008-05-15 3:46 PM (#84024 - in reply to #83966)
Paul,
I hate to ask a stupid question, what the heck is "screwworm smear"?
Thanks!
rose
Posted 2008-05-16 1:15 AM (#84051 - in reply to #83966)
10005001002525
I am glad you asked that....'cause I was wondering too. I know about the purple screw worm spray but....
When I pull ticks off the dogs or me, I drop the evil things in a jar of rubbing alcohol then put the lid back on.
Posted 2008-05-16 9:51 PM (#84100 - in reply to #84051)
1000500100100100252525
 rose I just have to ask why do you keep the little bug ,I just kill the bugs??
jackbrat
Posted 2008-05-17 12:26 AM (#84105 - in reply to #83966)
500100
I agree with the "spot-on" stuff. It has worked with my horses really well. You just have to keep up with it at every 14 days though. Another thing that works well for horses with "sensitive" skin, skin that the fly's  and those little "no see-ums" (black nats)just love on the under side of the belly.   T- zon  . This stuff is awesome. I tried everything last year. Swat, and all the others to no avail.
 T-zon  has Tea tree oil and Hydrocortisone for the itching. I have completely eliminated the raw line under my gelding's belly that went from his hind legs all the way to his front legs. (He was sooooo miserable last year!)
Posted 2008-05-17 8:54 PM (#84136 - in reply to #84024)
Originally written by barntoys4mom on 2008-05-15 4:46 PM
Paul,
Thanks!
smear contains 3 percent of lindane and 35 percent of pine oil
This was developed by cattlemen...
http://www.lindane.com/?gclid=CO-19Z74rpMCFQLBsgodUyusnw
crowleysridgegirl
Reg. Apr 2005
Posted 2008-05-19 4:15 PM (#84240 - in reply to #84105)
2000500100
Where do you find T Zone?
Posted 2008-05-19 11:03 PM (#84283 - in reply to #84240)
Originally written by crowleysridgegirl on 2008-05-19 5:15 PM
T-ZonĀ®
Equine Dermal Care Cream
http://www.healing-tree.com/T-ZonEquine.html
Edited by PaulChristenson 2008-05-19 11:06 PM
Posted 2008-05-19 11:05 PM (#84284 - in reply to #84283)
Duplicate post...
Edited by PaulChristenson 2008-05-19 11:07 PM
brightemiller
Reg. Apr 2007
Posted 2008-05-20 9:25 AM (#84320 - in reply to #83966)
hey guys.. it's great to share ideas and tricks that have worked. i'm gonna try the t-zon stuff. here in the south, ticks are bad. i have had luck with skin-so-soft by avon. stinks but if you put it around your horses feet before you ride in the sandy soil it really helps keep the critters from hitching a ride up their legs. and it's safe. i soak their manes and tails in it and it helps with tangles too. and for around the barn, guineas are awesome. squawky birds, but they love to eat bugs and ticks!
jackbrat
Posted 2008-05-21 11:58 PM (#84433 - in reply to #84240)
500100
Paul beat me to it!!
 I ordered a whole case of the stuff. Got a great price, ended up being 12 bottles for like $120- instead of paying $12-14 per bottle! Dr. Witherspoon is great. Met him at the local Horse Expo here in Sacramento Ca.
The
Tea-Clenz" shampoo (antimicrobial anti-fungal) is great stuff too.
jackbrat
Posted 2008-05-22 12:04 AM (#84434 - in reply to #84320)
500100
Brightemiller,
The T-Zon is a cream for the "bad" spots like raw and or flaky skin areas. It isn't a "spray" that you would use over the entire body.
