propane & battery holders
Last activity 2008-06-02 10:45 PM
4 replies, 4766 views
horsin around
Reg. Jun 2005
Posted 2008-05-11 10:09 AM (#83688)
Subject: propane & battery holders
100100100
Currently I have a single battery and propane tank and would like to add another of each.
Would anyone know where I can find racks single or double to hold your battery and propane tanks? Thanks!
karynzoo
Reg. Mar 2008
Posted 2008-05-12 1:02 PM (#83773 - in reply to #83688)
Subject: RE: propane & battery holders
I have the same question/issue.  Need to add a second propane and battery.
Posted 2008-05-12 1:05 PM (#83775 - in reply to #83688)
http://www.solarseller.com/battery_boxes_by_quick_cable.htm
http://www.rvpartscenter.com/ProductDetail.asp?PID=19174&SID=32&DID=93&CID=281
Edited by retento 2008-05-12 1:07 PM
HTWOK
Reg. Sep 2007
Posted 2008-05-13 10:46 AM (#83839 - in reply to #83688)
You can also get an switch for the dual tanks that will automaticly switch tanks when one runs out.  Also any good machine/welding shop should be able to manufacture you the racks that you need.  On your battery boxes there should be vents on them for them to be up to code to be in compliance with RVIA code.
karynzoo
Reg. Mar 2008
Posted 2008-06-02 10:45 PM (#85104 - in reply to #83688)
I was trying to figure out how I'd get the racks on the front for the propane and battery since the LQ is already finished.  These can be welded as opposed to bolted on?
