FORD SUPER DUTY OWNERS PLEASE NOTE
Last activity 2008-05-09 8:35 AM
12 replies, 6308 views
Posted 2008-05-07 4:20 PM (#83431)
Subject: FORD SUPER DUTY OWNERS PLEASE NOTE
Yesterday, while inspecting my truck for this summer's use, I found some oil leaking underneath the rear differential. When I cleaned the area to determine from where it was leaking, I made a disturbing discovery. It was leaking from the surface of the rear inspection plate.
Poking at the area with a screw driver resulted in a larger leak. The plate had rusted through! A call to our Ford dealer revealed that "some" trucks were shipped with plates made of "soft" ( whatever that means) metal and were rusting out after the warranty, but young in the truck's life.
I've been a mechanic a long time and have never seen this happen on any make of vehicle. The bottom line is, check your truck if it's the early series Super Duty. Not to do so could be a very expensive mistake. The plate is about $60, and the special 75 -140 weight synthetic oil for posi units is another $60.
BOL  Gard
Posted 2008-05-07 4:44 PM (#83441 - in reply to #83431)
Subject: RE: FORD SUPER DUTY OWNERS PLEASE NOTE
Seems like they had the same problem with some of the early 7.3 Power Stroke oil pans. They would have little pin holes rust in them. They had to pull the engines to R&R the oil pans!! It would cost the average unexpecting owner around 3K to have the pans replaced. I know several folks that traded their 2001 Super Duty trucks instead.
Edited by retento 2008-05-07 6:39 PM
captclank
Posted 2008-05-07 5:41 PM (#83446 - in reply to #83431)
Gard, what year is your Super Duty? Thanks
farmbabe
Posted 2008-05-07 6:23 PM (#83447 - in reply to #83431)
1000500100100
Retento- Our 2000 Ford has that same oil pan leak.We discovered the leak, ordered the oil pan and THEN was told we'd have to life the engine to replace it. I had a out of state show to attend in a few days and there was no way to get it done in time....so...
My husband cut the new pan to fit over the old one,put lots of silicon all over it,stuck it together with wire...its been that way for 4 years. We were later told in that model year the pans were not galvinized properly. anyway, it works now.
crowleysridgegirl
Reg. Apr 2005
Posted 2008-05-08 7:09 AM (#83475 - in reply to #83431)
2000500100
IMO if the pans weren't galvanized or made properly,Ford should have to eat the cost of repairing them no matter.warranty or not.A few lawsuits ought to come their way for THAT boo boo.
farmbabe
Posted 2008-05-08 7:23 AM (#83477 - in reply to #83431)
1000500100100
Thats the information we were given now I can't say its 100% accurate plus it would take years and years in courts to do anything abut it. Since its been what, 8 yrs and nobody has sued, I' have to think it wasn't a big deal.
Posted 2008-05-08 8:48 AM (#83489 - in reply to #83431)
The replacement cover plate I purchased yesterday was not galvanized. It however, was physically heavier than the original part it replaced.
Edited by gard 2008-05-08 8:50 AM
farmbabe
Posted 2008-05-08 9:08 AM (#83492 - in reply to #83431)
1000500100100
Gard the part I was referring to was the oil pan and that was 4 yrs ago.
Posted 2008-05-08 9:36 AM (#83494 - in reply to #83431)
I hope the oil pan replacement isn't in my future
farmbabe
Posted 2008-05-08 11:20 AM (#83508 - in reply to #83431)
1000500100100
if it is, we ave a very easy fix.......but the mechanic in you probably couldn't stomach it...
chadsalt
Posted 2008-05-08 12:53 PM (#83521 - in reply to #83447)
1000100100100100
Originally written by farmbabe on 2008-05-07 6:23 PM
Damn, now thats resourceful. Probably would drive me nuts knowing it was like that, but resourceful none the less.
rattler
Posted 2008-05-08 3:31 PM (#83532 - in reply to #83431)
The 7.3L oil pan rust issue is widely known and discussed in the powerstroke community with many using POR-15 kits to treat the pans. I have seen a product, but can't put my hands on the web site at this time, that was manufactured to do just what farmbabe did without it being a complete pan....sort of like a shoe cover that fit exactly over the pan and held in place by some type sealant. Pulling a motor to replace an oil pan is a bitter pill and bill to swallow. Some have found Ford dealerships that will drop the tranny and jack the engine in place...apparently there is enough room to do it without pulling the motor  but there is questions as to how good a seal is accomplished in this manner. Apparently Ford recommends taking the engine out, flipping in over and allowing the silicon bead and new pan to setup over night and if that is what it says in the service manual then that is what most service departments and technicians will do.
Posted 2008-05-09 8:35 AM (#83580 - in reply to #83508)
Originally written by farmbabe on 2008-05-08 12:20 PM
I'll entertain many ideas before spending $3k! I like easy, and prefer inexpensive.
