GVWR Question
Last activity 2008-05-22 8:41 AM
18 replies, 7119 views
TPompei
Reg. Jan 2011
Posted 2008-04-28 7:34 PM (#82755)
Subject: GVWR Question
While pulling a three horse trailer with a living quarters, I stopped at the scales this weekend on my way to camp just to see how heavy I was.Did I do the math correctly here?Steering axle 5460Drive axle 6380Trailer axles 8600I have an 08 F350 with a long bed, so my GVWR is 11,400. If I add the weight on the truck axles, I'm at 11,840 , 440 lbs over. Is this correct? I had a 30 gallon water tank in the bed of the truck, about 250 lbs. But I only had one horse in the trailer. Hmmm.I thought with the one ton I'd have plenty of capacity, but it seems like I have too much tongue weight on the gooseneck. Any recommendations? Heavy in Dayton,Tom
crowleysridgegirl
Reg. Apr 2005
Posted 2008-04-28 9:26 PM (#82767 - in reply to #82755)
Subject: RE: GVWR Question
2000500100
I'm  not sure about adding the weights together,we've weighed our 3H LQ (12'SW) and it weighed about 7Kempty,I think. But I would think your 1T would be plenty to pull it with.
Terri
Posted 2008-04-28 9:39 PM (#82770 - in reply to #82755)
200050010010010025
Your truck weight (GVW) is the front plus rear axle, the truck axles plus the trailer axles is the CGVW.   If you weighed the trailer with no horses there was no weight in the back to "even out" the trailer load and may have made it a bit nose heavy.  Especially if your trailer has a heavy LQ.
Check and see what your axles are rated for to see if you were over their limits.
Posted 2008-04-28 10:20 PM (#82774 - in reply to #82755)
It's not uncommon for a LT truck to exceed it's GVW while pulling a GN trailer. It however, may be within its CGVW and not exceed its tow rating.
In PA, my truck was a class 3 and I was overweight while pulling my larger trailer. By having my title changed to a "Combined" classification, my weight classification is now a class 7 which reflects the CGVW, the total weights of the truck and trailer. I'm legal to pull the larger trailer and it's within Ford's combined pulling specs. The downside is my registration fee which is now doubled.
Posted 2008-04-29 9:55 AM (#82786 - in reply to #82755)
Originally written by TPompei on 2008-04-28 6:34 PM
Hi Tom ... You are correct in figuring your truck weight.  Removing the water tank from the truck will net you 200 pounds over your GVWR  ... Not a significant overload IMHO... Did you have the one horse in the front stall?  Placement of the horses will have a great effect on the hitch weight.  Horses in the last stalls will balance more of the trailer weight on the trailer wheels, less on the truck.
TPompei
Reg. Jan 2011
Posted 2008-04-29 12:54 PM (#82790 - in reply to #82755)
I had one horse in the back stall, so that should have helped.I'm wondering if I put the water tank in the rear tack, and don't haul with a full LQ water tank, if that will be sufficient. I'm thinking not.I'm going to look into trading the truck in for a dually or a F450.
Posted 2008-04-29 3:46 PM (#82797 - in reply to #82790)
Originally written by TPompei on 2008-04-29 11:54 AM
Dually ???  I thought you said you had a one ton truck ??  If you have a single rear wheel truck ... regardless of the badging, IMHO it's a tarted up 3/4 ton truck.  I take back what I said about 200 pounds being an insignificant  overload.  With a single rear wheel, a tire failure is a significant problem.
Edited by hosspuller 2008-04-29 3:48 PM
chadsalt
Posted 2008-04-29 4:03 PM (#82799 - in reply to #82797)
1000100100100100
Originally written by hosspuller on 2008-04-29 4:46 PM
I believe the SRW F350 has a rear axle rating of 7000+,  tire failure shouldnt be a problem.
wyndancer
Reg. Apr 2007
Posted 2008-04-29 4:15 PM (#82802 - in reply to #82755)
chadsalt,How does Ford get 7000+ on the rears of a SRW when a typical 10 ply tire doesn't rate over 3300lbs when mounted singly?
chadsalt
Posted 2008-04-29 5:02 PM (#82806 - in reply to #82802)
1000100100100100
Originally written by wyndancer on 2008-04-29 5:15 PM
With "non typical" 18" and 20" tires.  My neighbour has a SRW F350 with 275/70/18 rated at 3640 @ 80 psi.
chadsalt
Posted 2008-04-29 5:37 PM (#82807 - in reply to #82755)
1000100100100100
...........his doors were locked so I dont know what the rear axle rating is but I suspect its 7280.
I remember him giving me crap about how his shiny new Ford had a rear axle capacity of nearly my GMC's GVWR (9200).
Spooler
Reg. Aug 2006
Posted 2008-04-29 7:49 PM (#82814 - in reply to #82797)
50025
Originally written by hosspuller on 2008-04-29 7:46 PM
Amen, we think alike hosspuller.
TPompei
Reg. Jan 2011
Posted 2008-04-29 8:52 PM (#82816 - in reply to #82755)
Hosspuller and Spooler, thank you for your opinion on the F350 being or not being a one ton. You seem very passionate on that point.The single rear wheel axle rating is 7000 lbs, so I'm still underweight on the rear axle.
Posted 2008-04-29 9:39 PM (#82820 - in reply to #82816)
Originally written by TPompei on 2008-04-29 7:52 PM
Tom ... The 1/2, 3/4 & one ton series trucks are just classes of truck.  To me, it's a marketing ploy to call a single rear wheel truck a one ton truck.   Kinda like grade inflation.  A "B+" is now an "A"
You're 600# underweight on the rear axle with a single horse in the rear stall.  What will the axle weight be when you've got three horses and a weeks worth of supplies aboard?
Posted 2008-04-29 10:50 PM (#82824 - in reply to #82755)
There are numerous tires in Load Range E that will get you over the 3500lbs per tire rating.
By steping up one size  (from 275 to 285) you can get over 4000lbs per tire, that would give you an 8000lb rating, If the axle, lugs, and wheel would handle it.
copied from Toyo spec page.
LT285/75R18 129P E/10 360420 7.5-8.0-9.5 71 19 35.1 11.6 16.3 4080 80
My next truck will be a dually if I keep my current trailer.  Like the original poster I have a F350 SRW and I am just under on the front axle, right at the max rear axle and real close to the max GCVW with 4 horses, supplies for the week and my family in the truck. Since I don't very often take the whole gang with me, Most trips I'm under. If I load the whole gang, I'm much more careful about putting anything that has any weight, in the bed of the truck. No extra water etc.
It would be nice to own two trucks, One for a daily driver/work truck and one for the horse trailer.
Posted 2008-04-30 8:50 AM (#82839 - in reply to #82824)
Originally written by Painted Horse on 2008-04-29 11:50 PM
The big three would love to sell you one. Gm just layed off a shift in several plants because of low truck and SUV sales. Fuel prices are taking their toll.
TPompei
Reg. Jan 2011
Posted 2008-04-30 11:02 AM (#82844 - in reply to #82820)
I'll try moving the extra water tank to the rear tack.  Also, if I put in more horses, most of that horse weight will be over the trailer tires.
I was loaded to the gills with the one horse, extra hay, cast iron pots and skillets, tons of water, wife and dogs, etc....
Thanks for all the help.
TPompei
Reg. Jan 2011
Posted 2008-05-22 8:07 AM (#84444 - in reply to #82755)
I loaded up two horses, no water/wife/dogs, and weighed the rig.  It's very interesting;
drive axle weights:
empty trailer / fuel full:  5780
1horse/water 80g/full fuel/wife/dogs:  6380
2horses/.5 fuel tank/empty water:  5840
I think the horse weight is pretty much staying over the back trailer axles.
Next I'll try water tanks full and 2 horses to see what I have...
Posted 2008-05-22 8:41 AM (#84447 - in reply to #82755)
Some weights to remember....
Water 8.333# per gallon
Diesel fuel 6.951#-7.076# per gallon, a little heavier in the winter
Unleaded Regular 6.146# per gallon
Unleaded Premium 6.263# per gallon
