Trailer Wiring Question
Last activity 2008-04-19 9:45 PM
4 replies, 4457 views
jrwest2
Reg. Apr 2008
Posted 2008-04-18 2:54 PM (#82226)
Subject: Trailer Wiring Question
 I just bought a new trailer Fith Wheel trailer and hauled it the other day everything works fine but when i apply the brakes my lights go out.  I have a 2008 f-350 and it tells me my trailer  plug has disconnect but everything seems fine.  Is it that my trailer is not grounding properly
Posted 2008-04-18 6:26 PM (#82238 - in reply to #82226)
Subject: RE: Trailer Wiring Question
Do you have a short in the brake light wiring circuit?
Posted 2008-04-18 8:55 PM (#82241 - in reply to #82226)
Originally written by jrwest2 on 2008-04-18 3:54 PM
Are you blowing fuses? If so, you are looking for a short to ground in your trailer wiring most likely. Take your voltmeter, put it on ohms and check for continuity from your leads to the trailer chassis. Only one should read zero ohms, the wihte one usually. If any of the others do read zero ohms then you have a short that is blowing you fuses.
jrwest2
Reg. Apr 2008
Posted 2008-04-19 9:45 AM (#82269 - in reply to #82226)
I am not blowing any fuses. It's almost like when i apply the brakes my truck is loosing contact with the trailer. As soon as you stop everything comes back or if your moving everything is fine. It just seems to be when slowing down.
robdnorm
Posted 2008-04-19 9:45 PM (#82294 - in reply to #82226)
500
Do you have anything in the bed that is coming in contact with the trailer cord?  I had a a piece of pipe that wreaked havoc with me one time until I figured out that it was causing my troubles on my connection.  Just a thought.
Edited by robdnorm 2008-04-19 9:47 PM
