Replacing the floor
Last activity 2008-04-20 10:14 AM
9 replies, 6144 views
kanchazer
Posted 2008-04-10 11:49 AM (#81649)
Subject: Replacing the floor
Hot Dispatcher
Has anyone repalced the floor in an aluminium trailer?? How much did it cost and did you have any problems??
Posted 2008-04-10 7:49 PM (#81678 - in reply to #81649)
Subject: RE: Replacing the floor
It's a very laborious project, varying greatly from trailer to trailer, and the type of aluminum materials being used. The final cost could be in the thousands of dollars.
It might be less expensive in labour and materials, to retro fit it with a new wooden floor.
TERP
Reg. Sep 2006
Posted 2008-04-13 10:18 AM (#81795 - in reply to #81649)
Depending on the condition of your floor you could just put WERM on it and that would protect your floor and  eliminate any future corrosion. www.wermflooring.com
Posted 2008-04-13 12:04 PM (#81803 - in reply to #81649)
Before you can appy a Werm product, you have to have a structurally sound floor, that has had the corrosion issues addressed and corrected. The Werm should be applied when the floor is in a new condition, to keep it from being damaged.
TERP
Reg. Sep 2006
Posted 2008-04-14 5:53 AM (#81854 - in reply to #81649)
that is why I said DEPENDING ON THE CONDITION of the floor!
rockyrider
Reg. Jun 2004
Posted 2008-04-14 6:07 AM (#81855 - in reply to #81854)
100100100
Originally written by TERP on 2008-04-14 5:53 AM
What dat mean?
Posted 2008-04-14 6:57 AM (#81859 - in reply to #81649)
If the floor needs to be changed, I would doubt that it is in a good condition. Wouldn't you assume that is the basis for her question? PLEASE HAVE A NICE DAY!
4everenbluejeans
Reg. Jul 2007
Posted 2008-04-14 8:58 PM (#81924 - in reply to #81649)
wood over the alum. flooring, then mats?  Would that work?  Our old Sooner trailer has the alum floor and it is warped.  Solid and still good, but the little drain holes they drill at the factory are worthless. My son put in some new ones to help it drain and I have toyed with a new floor.  Could a person put down pressure treated plywood over the exsisting floor to create a cooler floor?  Or shoud I just invest in new mats?  I would actually sell tihs trailer and start over again on the LQ if I could afford to get one wtih a 6' short wall.   Heaven forbid I say this at the start of show season!
One never has enough room once they are all done,
Jeanne
Posted 2008-04-14 10:17 PM (#81930 - in reply to #81649)
The wood flooring obviously could be placed over the aluminum, but then you would have the problem of moisture and urine being trapped between the two surfaces. There would be no opportunity to dry things out. If you use the treated lumber, it normally should last many years. I don't know if the combination would be detrimental to the longevity of the wood.
I think if it were my trailer, I would cut out the metal flooring between the floor joists, and install the wood over the rest. It would only take an hour or so with a jig saw or sawszall, to remove the metal. I think as a result, it would make for a longer lasting floor .
Aluminum is a good conductor of cold and heat, The wood has a natural insulating factor, and should be cooler to the horses feet, while trailering on a hot day. Placing mats over the wood, adds further insulation, protects the wood from abrasion and fluids, and quiets the ride.
4everenbluejeans
Reg. Jul 2007
Posted 2008-04-20 10:14 AM (#82305 - in reply to #81649)
thanks.  that sonds like a plan for htsi winter when the guys need something to do.  The floor is sound, but the warping bothers me.  A trailer company said that is because alumimun stretches and that is why it sags.  There is a neat new seamless rubber flooring that can be done, but it is pricey. About $350 a stall Not what I want to put in an older trailer.  Although its been said the older Sooner trailers are made better than the new ones.
Wood would be the most affordable option and the cool and quiet woudl be nice. In the dressing area I insulated the floor before adding the plywood and laminate.
have a great day
Jeanne
