Plumbing Questions
Last activity 2008-04-09 9:48 AM
2 replies, 3570 views
Mandi/Abby
Reg. Sep 2003
Posted 2008-04-08 3:54 PM (#81463)
Subject: Plumbing Questions
Charter Member
Is there a minimum distance required between my water tank & water pump?
What about between the water pump & accumulator tank?
Water heater & water pump?
Water heater and surrounding walls?
Anything I've forgotten?
Posted 2008-04-08 7:10 PM (#81474 - in reply to #81463)
Subject: RE: Plumbing Questions
I suspect your question is in regards clearance so it does not ignite items that may be close by. I don't know what brand of water heater you have.  And each may differ.
But my water heater has a foam insulation around it. I would suspect I could place pretty much anything next to that, Because the foam surrounding the unit would catch fire before anything sitting next to the water heater.
If you are concerned about pressure.  I would find it hard to believe that the items you listed would care if the were 2" or 2 feet apart.
Mandi/Abby
Reg. Sep 2003
Posted 2008-04-09 9:48 AM (#81505 - in reply to #81463)
Charter Member
I wasn't concerned about pressure, I just wasn't sure if there was a distance any of those items had to be spaced apart.
