Windows Won't Slide
Last activity 2008-03-23 6:26 PM
3 replies, 6087 views
Angelmay84
Reg. Jan 2008
Posted 2008-03-23 11:53 AM (#80179)
Subject: Windows Won't Slide
Now that the weather is getting a little better, I tried to open the windows on my "new" old horse trailer.  They are supposed to slide in a track.  They don't slide worth a hooey.  It's a battle to get them open.  Can I put some sort of lube in the track to make them open easier?  I'm not sure what the track itself is even made of.  I have an older lazy N trailer.
Amanda
Posted 2008-03-23 12:27 PM (#80187 - in reply to #80179)
Subject: RE: Windows Won't Slide
This is what I use...
http://www.crcindustries.com/auto/content/prod_detail.aspx?PN=05074&S=N
Just spray it in the track then slide the window to work it in. I usually spray all of mine about twice a year. Makes it alot easier when the 56" windows are at arms reach.
Flooper
Posted 2008-03-23 4:05 PM (#80204 - in reply to #80179)
I second retento's recommendation. I use the same stuff on my 96 Sundowner and the windows slide much easier after I apply it. Also, make sure you clean the tracks out...sometimes they get junk in them that make the windows hard to open.
Posted 2008-03-23 6:26 PM (#80213 - in reply to #80179)
If the latches are tight or the metal is stuck together, try the same company's CRC 5-56. It is an excellent penetrant/lubricant. Once the metal parts are moving, the silicone spray will keep it that way.
