generator warning
Last activity 2008-03-25 1:55 AM
14 replies, 5992 views
TPompei
Reg. Jan 2011
Posted 2008-03-23 11:42 AM (#80177)
Subject: generator warning
I have a 3 way safety light plugged into a 120 outlet in the LQ. I hooked up the generator for a test run today, and the lights indicated HOT/NEU REVERSE. Do you think this is LQ wiring mistake or a generator issue?When I plug into shore power, 110, 15 amp, the lights read correct. I haven't yet plugged into shore power 30 amp service yet.Thanks and Happy Easter!
Posted 2008-03-23 11:48 AM (#80178 - in reply to #80177)
Subject: RE: generator warning
What make and model generator you running? Were you plugged into the 30 amp on the generator or to a 15 amp plug?
Edited by retento 2008-03-23 11:49 AM
TPompei
Reg. Jan 2011
Posted 2008-03-23 12:57 PM (#80188 - in reply to #80177)
I'm running two Honda eu2000i linked together (with the Honda connector) with the 30amp trailer plug. I tried reversing the connector cables on the generators. I also tried running one generator only with the 120v 15 amp plug adapter from the LQ, -- same warning light.
Posted 2008-03-23 3:08 PM (#80199 - in reply to #80177)
See, I don't know anything about that deal of tying two 2000's together. You get 4000 watts but still only 20 amps. Who wired up your 30 amp plug? Are the wires in the correct place inside your 30 amp plug? Are you using any type of home made adapters? Is the generator grounded, like with a ground wire, grounded to earth, into the soil? Is the generator grounded to the trailer? I'm no electrician, just trying to give you some clues to look for the problem. Look around on this site, you might stumble upon something....
http://www.rv.net/forum/index.cfm/fuseaction/listings/forum/39.cfm
Edited by retento 2008-03-23 3:12 PM
walkin
Posted 2008-03-23 4:24 PM (#80205 - in reply to #80177)
500100
Mine does the same thing.  Somebody told me to put a ground w ire on the generator and ground it to the truck bed[where I keep mine].
If I am at a campground and it reads wrong I disconnect till I get get a repairman to look at it.
Snickers
Posted 2008-03-23 4:43 PM (#80207 - in reply to #80177)
Have same set up as you, two Honda gens hooked together and have not had any problems. You do get 4000 watts peak and 33 amps. Does everything work correctly when you are connected to shore power? I would look at you 30 amp plug.
Posted 2008-03-23 5:59 PM (#80210 - in reply to #80205)
Originally written by walkin on 2008-03-23 5:24 PM
You can NOT ground to the truck...
Posted 2008-03-23 6:01 PM (#80211 - in reply to #80177)
Plug your test plug directly into a generator outlet...if it shows OK...then your 30 AMP PLUG is miswired...
Posted 2008-03-23 9:10 PM (#80232 - in reply to #80211)
Originally written by PaulChristenson on 2008-03-23 5:01 PM
BINGO !... Paul  .... you're a true diagnostician
TPompei
Reg. Jan 2011
Posted 2008-03-24 4:11 PM (#80275 - in reply to #80177)
I plugged the tester into the generator and got the same warning "Hot/Neu. Reverse" Hmmm. How interesting...
walkin
Posted 2008-03-24 5:47 PM (#80278 - in reply to #80177)
500100
Why can't you ground to the truck.
mgisse
Reg. Dec 2005
Posted 2008-03-24 6:05 PM (#80281 - in reply to #80177)
Read your owners manual for the generator and make sure that it is normal for the two to be switched on the tester. There is a few generators that the testers do not work properly with . This is normal and it shouldent be a problem it is usually just the way the tester reads the power from the gen.
flyinghfarm
Posted 2008-03-25 12:31 AM (#80318 - in reply to #80177)
1000100100
I am not certain this is the grounded that is being discussed, but I believe the truck is setting on it's tires, thus insulated from being grounded, at least not the same as having a rod driven into the dirt and grounded that way...
Posted 2008-03-25 1:53 AM (#80324 - in reply to #80318)
Originally written by flyinghfarm on 2008-03-25 1:31 AM
BINGO...
Posted 2008-03-25 1:55 AM (#80325 - in reply to #80275)
Originally written by TPompei on 2008-03-24 5:11 PM
Well that's NOT GOOD...That would imply you have a miswired generator!!!
Does your second generator show the same problem?????
If it shows the same problem...I'd want to see another TESTER...
I would be surprised, if there were two Honda generators miswired in your possession
I get the feeling you are on your way back to your dealer...
Edited by PaulChristenson 2008-03-25 2:00 AM
