Need Info On Tankless Water Heaters
Last activity 2008-03-13 11:20 AM
6 replies, 4590 views
always amazed
Reg. Feb 2008
Posted 2008-03-12 1:54 PM (#79372)
Subject: Need Info On Tankless Water Heaters
I am going to install a cowboy shower and was wondering if the electric tankless water heaters would work. It lookes like something that could work. I will also have a sink in LQ's. Has anyone else used these or have any info?
equiteacher
Reg. Mar 2007
Posted 2008-03-12 2:50 PM (#79382 - in reply to #79372)
Subject: RE: Need Info On Tankless Water Heaters
We have a SEISCO tankless heater in our home and really like it - now.For the first two years we had a LOT of problems with the micro switches corroding. The company was very good about replacing them, but you never knew when one would go out, and then you were hung without hot water until they could ship you another one. They finally sent us several to have on hand when one failed. A couple of years ago they totally changed types of micro switches, and we have had no problems. They make two models specifically designed for RV's. http://www.seisco.com/pages/twochamber.html
greyhorse
Reg. Nov 2005
Posted 2008-03-12 9:08 PM (#79400 - in reply to #79372)
Should work great but you need to figure out if your electrical system can handle the load.
rose
Posted 2008-03-12 9:29 PM (#79401 - in reply to #79372)
10005001002525
We have an electric tankless water heater in our house and love it.  Tankless water heaters are also made for propane.  We got ours from Barnett in LA;  their toll free no. is 866-384-0500.
riddenhardputawaywet
Posted 2008-03-12 10:48 PM (#79404 - in reply to #79372)
Check out ebay item# 110207113454
Ive been eyeing one of these for a while, the price is right....
always amazed
Reg. Feb 2008
Posted 2008-03-13 10:27 AM (#79451 - in reply to #79372)
You all have brought up many questions. I was wanting to use this for my only source for a water heater. Would that work?? Why would I not have the electric capacity to handle it??
mgisse
Reg. Dec 2005
Posted 2008-03-13 11:20 AM (#79465 - in reply to #79372)
The tankless heaters need at least 40 amps to work most trailers are 30 amps . So you would need at least 50 amp sevvice to use the WH that dosent leave you with any extra amps to run anything else at the same time. Like your Ac , a hair dryer , the refer on 110.
