TV goes digital
Last activity 2008-03-10 2:03 PM
12 replies, 6680 views
stablemom
Reg. Jun 2007
Posted 2008-03-08 11:44 AM (#79006)
Subject: TV goes digital
What happens to our TV's when the big change occurs next year? Am I right to think that we will not get reception with our little LQ TV's?
Posted 2008-03-08 11:57 AM (#79008 - in reply to #79006)
Subject: RE: TV goes digital
Any one with a cable or dish system will be ok. A converter will be necessary for anyone using a conventional  antenna system. It has been estimated they will be aprox $50. The only recourse would be to purchase a replacement HD TV.
I have yet to see a 12V HD TV and have not found any in the electronics stores. I would think that with the large RV and marine markets, they will soon be available.
Terri
Posted 2008-03-08 11:46 PM (#79061 - in reply to #79006)
200050010010010025
You can order a coupon for a free converter box.  I saw it on line, I'll have to see if I can find the link again but you can try searching for digital tv coupon or something like that.
Here it is.  http://www.ntia.doc.gov/
Edited by Terri 2008-03-08 11:48 PM
stablemom
Reg. Jun 2007
Posted 2008-03-09 10:32 AM (#79079 - in reply to #79006)
Will you still need the antenna with the converter box? Do they work together? Sorry, not too smart when it comes to this stuff. I see how the converter box helps when you are with cable, etc... but not sure how I understand how a converter box helps with just the TV & antenna when you are out on the road.
Bet those small HDTV will be quite expensive!
stablemom
Reg. Jun 2007
Posted 2008-03-09 10:35 AM (#79081 - in reply to #79006)
Also, how do you have cable TV in a LQ trailer?
Posted 2008-03-09 11:02 AM (#79082 - in reply to #79006)
If you have a signal that is supplied by a cable or satellite TV company, their signal will work on your non HDTV.
If you have a conventional antenna, the new signal that it will receive will not be compatible with your present non HDTV. It will need a converter to change the new signals into a recognizable format that will work on the older TVs. As was mentioned, coupons are available from the government for the approximate cost of the converter.
If you are using a conventional TV in your LQ, you will have the same problems and be subjected to the same ramifications as your home TV.
huntseat
Posted 2008-03-09 11:06 AM (#79083 - in reply to #79079)
1000500100100100100252525
The converter box converts the signal down to your TV from a digital signal, think of it like the black AC converter boxes on power-cords.  Your antenna receives the signal, which then will need to be converted so that your non-digital TV can read it and produce images and sound.
I believe that every household can sign up for 2 free converter boxes.  You need to get on that website pronto!
The industry isn't in a rush to release converter boxes because they want you to buy newer TV's...thankfully for the public they were forced to push back the original date for the transition.  Really sad thing is that the cheaper "new" TV's on the market still will need the converter boxes and those consumers have no idea that they just spent $700 on a new flatscreen that isn't equipped to handle the new technology!
If you have specific questions I can forward them on to my father and brother which work in the telecom industry and run a home theatre business on the side.  It's best not to ask a salesman, but someone who can give you honest information about what you will/won't be needing for the conversion.  (You don't take horse advice for someone selling you a horse either.)
stablemom
Reg. Jun 2007
Posted 2008-03-09 11:33 AM (#79088 - in reply to #79006)
Thanks so much for all the info! I will get me a coupon for the box!!
genebob
Reg. Nov 2007
Posted 2008-03-09 11:43 AM (#79089 - in reply to #79006)
gard- not to be a nit picker, but it is digital format that is needed not Hi Def. Most TV's sold in the last five years are already in digital mode. Not sure about the 12 volt models , but owners manual would tell you.
Posted 2008-03-09 12:10 PM (#79093 - in reply to #79006)
I stand corrected
califhorseman
Reg. Feb 2008
Posted 2008-03-09 9:37 PM (#79144 - in reply to #79006)
You can get a coupon for $40.00 towards the convertor box
wyndancer
Reg. Apr 2007
Posted 2008-03-10 12:02 PM (#79177 - in reply to #79083)
Here's the question.My HT has the crank-up Winegard antenna....what is gonna change? Or will it work?
genebob
Reg. Nov 2007
Posted 2008-03-10 2:03 PM (#79203 - in reply to #79006)
The antenna will still work. You either need a digital TV or the converter.
