Plumbing question!!!
Last activity 2008-03-07 9:40 PM
3 replies, 4918 views
FL_BWAB
Reg. Dec 2004
Posted 2008-03-07 2:47 PM (#78941)
Subject: Plumbing question!!!
Ok...ive gotten this far without any major goofs. Now Im clueless about plumbing. Does anyone have pictures of their plumbing set up and what they used. So far I have the water tank, pump, hot water heater and cowboy shower. I was told Pex was the stuff to use but what size tube? and the "flair it" fittings? Any pictures or advise would be great!!!!
HWBar
Reg. Nov 2005
Posted 2008-03-07 3:30 PM (#78945 - in reply to #78941)
Subject: RE: Plumbing question!!!
1000100100252525
I used CPVC for years an it worked fine, I have just recently converted to pex. I use 1/2" pex now and I'm on my second trailer with it, it is easier than CPVC(Because it needs no glue) but the tool is expensive($170). The older trailers I did with CPVC are still going fine. I use the stainless faucet hoses to make all connections from fixed plumbing to components i.e. water heater, faucets, toilet ect............ 1/2" FIP to 1/2" FIP works good that way.
Posted 2008-03-07 5:54 PM (#78958 - in reply to #78941)
1/2" Pex is fine,  But 3/8 will work just fine, the little pump in your trailer can't pump enough to overload 3/8".
All faucets that you can buy now days are limited to 2 gallons per minute and 3/8 pex will easilly do that.
Home Depot, Lowes etc usually rent the tools.
Here is a quick and dirty diagram
Edited by Painted Horse 2008-03-07 6:07 PM
daywork
Reg. Mar 2006
Posted 2008-03-07 9:40 PM (#78975 - in reply to #78941)
Just did some water works in the house and did away with the problem plastic with pex.They have a fitting called shark bit that are really easy to install and also take apart with a cheap tool.The fitting are expensive, but if you mess up or change your mind it really easy to take the fittings off and do it again.
