Where to place generators
Last activity 2008-03-06 7:11 PM
18 replies, 9624 views
TPompei
Reg. Jan 2011
Posted 2008-03-04 7:38 PM (#78650)
Subject: Where to place generators
I'm going to run two Honda eu2000 portable generators (hooked together) for a three horse slant load with a 10 ft. short wall LQ. Since the generator documentation says they can't be run out in the rain, where is a safe place for them to be running if needed in inclement weather?
pegasus
Reg. Mar 2005
Posted 2008-03-04 8:09 PM (#78652 - in reply to #78650)
Subject: RE: Where to place generators
Mine goes in the back of the truck bed under the gooseneck. It's out of the rain and works well. I can roll it out to refill the tank.
Posted 2008-03-04 10:51 PM (#78663 - in reply to #78650)
I typically leave mine in the bed of the truck also. Just make sure the exhaust is NOT pointed at anything that could melt or scorch.
Also if I have the generator runing in the bed of the truck, I'm very carefull about opening any windows on the front portion of the trailer.
Posted 2008-03-04 11:38 PM (#78669 - in reply to #78650)
Originally written by TPompei on 2008-03-04 8:38 PM
Two like EU series generators can be linked in parallel to increase available wattage through the generator outlets.
Now remember that's PARALLEL and NOT SERIES...
TPompei
Reg. Jan 2011
Posted 2008-03-05 5:21 AM (#78678 - in reply to #78650)
When you've run generators in the bed or under the gooseneck, did you experienced any problems with fumes in the living quarters?
Edited by TPompei 2008-03-05 5:23 AM
Posted 2008-03-05 7:11 AM (#78681 - in reply to #78678)
I rarely run the A/C. ( When camping at 8000 foot it's rarely hot enough to need A/C)
So my use of the generator is usually to charge the batteries, run the microwave or grill to cook with.  Both of these are fairly short term  run times. So I might run my generator for 1 hour per day. ( 15-20 minutes for breakfast and 40 minutes or so for dinner)  I just shut the trailer windows closet to the truck during that period and no I have not had any problem or smelled the generator fumes.
Snickers
Posted 2008-03-05 8:37 AM (#78690 - in reply to #78650)
Have two of the Honda EU 2000i gens these hooked together with the Parallel Cable Kit. find that if we use the microwave and the AC kicks on the gens will shut down. Not a big deal to turn off the AC for the short time the microwave is running. Not sure how long the gens will run till they run out of gas but you might look at an extended run fuel tank. Check out www.wisesales.com
Have not run these during bad weather but don't see any problem putting them under the gooseneck
Dan Mefford
Reg. Feb 2008
Posted 2008-03-05 9:22 AM (#78695 - in reply to #78650)
I might suggest that the Gennys be run from the top hayrack if you have one.  You will need to make a cover, but once up there you don't have to move them anymore.  They are out of the way and don't take up space below.  Check out www.hayrak.com and go thru the website for more info and ideas.  Click on Select Trailer width then choose a width and then click on picture to enlarge and give you some ideas.  You might also want to carry some addtional water on top.
Dan
www.hayrak.com
Posted 2008-03-05 9:38 AM (#78697 - in reply to #78695)
Originally written by Dan Mefford on 2008-03-05 9:22 AM
I might suggest that the Gennys be run from the top hayrack if you have one.    You might also want to carry some additional water on top.
Before you attempt this combination, a consideration of the total weights should be contemplated. Not only are the weights of the generators a major concern, but the fact that water weighs 8.34 pounds per gallon is a determining factor. A thirty or forty gallon tank, which is not a static loading, added to the generators is a significant amount of loading.
The placement of the rack, its construction and the construction of the trailer structure at the attach points, should all be carefully determined.
Posted 2008-03-05 10:00 AM (#78702 - in reply to #78650)
My EF3000iseB Yamaha is in the bed of the truck, got it covered with a big blue, (color matches gen set!) plastic, rectangular, upside down, tub/bin, that I bought from Walmart. If we are at a show and it begins to rain, I just back the truck back under the trailer and roll the generator to the tailgate and use the gooseneck as a shed. I just point the exhaust toward the outside and down wind. It's handy to have the generator with me, in the truck rather than on the trailer. Where ever I go, I got 3500 watts of starting power and 2800 watts running power, at the twist of a key!!
always amazed
Reg. Feb 2008
Posted 2008-03-05 10:06 AM (#78703 - in reply to #78650)
My concern with leaving the generator in the back of the truck is how do you secure it so knowone can steal it????
Dan Mefford
Reg. Feb 2008
Posted 2008-03-05 10:08 AM (#78705 - in reply to #78697)
Originally written by gard on 2008-03-05 9:38 AM
Gard is right these things have to taken into consideration.  Generally the rack must transfer the weight to the side walls of the trailer and not place any significant weight on the roof itself.  Any trailer that is strong enough to hold a tied horse will be strong enough to carry significant weight if it is distributed across the rack.
My Honda weighs about 125lbs.  Water is very heavy at 8lbs + per gallon and a few bales of hay at anywhere from 50 - 75lbs in our neighborhood.
It can add up.  Be sure your equipment can handle it.
Edited by Dan Mefford 2008-03-05 10:25 AM
horsey1
Reg. Dec 2004
Posted 2008-03-05 1:41 PM (#78730 - in reply to #78650)
And that's why they are called hayracks and not waterracks....I've seen several hayracks bent and folks wondering why, and all the while they're looking at a 100 gallon tank up there...!!!
Dan Mefford
Reg. Feb 2008
Posted 2008-03-05 2:05 PM (#78732 - in reply to #78730)
Originally written by horsey1 on 2008-03-05 1:41 PM
That is right, however if it is engineered to accept more weight, then you can haul some extra water.  We recommend checking out manufacturer's load limits.  Many racks are built with 1" square tubes - can't haul much but hay with that.  We, at http://www.hayrak.com/ have built using 1 1/2" square tubes and large 1 1/2" X 3" Mounting brackets.  All are heavy duty built with High Tech Alloys.  We have thought of developing a HayRak Lite version, but just as sure as we do it will be abused.
Edited by Dan Mefford 2008-03-05 2:09 PM
mnhunter
Reg. Apr 2006
Posted 2008-03-05 7:38 PM (#78750 - in reply to #78650)
I think it depends on where you are going to carry them.  If you are going to carry them in the back of the truck then that may be the best place to run them.  Just be aware the 2000 honda is very portable for anyone that may want to borrow one for a few years.  Because they are pull start, I think the hay rack would be the wrong place for them.  Would be to easy to get hurt falling off trying to start them.  I carry my Yamaha 2400 in the tack compartent under the saddles and set it outside when using it.  If im in a crowded camp, I have even set it inside the trailer so no one else has to listen to it.  Usually set it under the gooseneck and run it there.
CTR Rider
Posted 2008-03-05 8:49 PM (#78758 - in reply to #78650)
I haul my Honda 3000 in the pickup bed also.  I have it locked with a cable to one of the rings in the truck bed. I keep a cover on it when I am not camping--- have not had a problem.   If I need to use it and it is raining, I have a big piece of rigid plastic that I put on top to keep the rain out.
Posted 2008-03-06 2:04 PM (#78815 - in reply to #78758)
Originally written by CTR Rider on 2008-03-05 9:49 PM
BE CAREFUL OUT THERE...
ACE 58918 BOLT CUTTER 18" VPT
Paints
Posted 2008-03-06 2:51 PM (#78820 - in reply to #78650)
WOW bed of truck.We did that once and where too worried would be too temping for it to walk away.Now ours is locked in back tack compartment(horsetrailer-nothing close by or next to it)and always remove key when not using it.In todays world most places that back truck generators gonna walk away.Or as posted somewhere earlier Stolen from top off trailerlqs.Just open door on tack comp. when running and till cools off and lock it up later.So that that generators always there when you need it.
longearsrule
Reg. Apr 2006
Posted 2008-03-06 7:11 PM (#78846 - in reply to #78650)
100100100
I have a Onan 5000 or maybe 5500, can't remember at the moment, LP generator mounted in the back of my truck with two bottles mounted next to it. The exhaust is vented thru the bed of the truck. I have a plug on the side of the bed to hook the trailer up and also have a cord on the trailer to plug into another plug on the bed for the remote start. If someone wants to steal it they will have to have some tools and some time.
