tongue extension
Last activity 2008-03-07 8:50 PM
9 replies, 8230 views
dbelling
Reg. Aug 2005
Posted 2008-03-02 5:59 AM (#78450)
Subject: tongue extension
After much feedback and questions I finally had my trailer tongue extended on my bumper pull trailer.  I needed an additional 12" due to my truck camper and trailer being too close.  My choices were to buy the superhitch at about $800 or take my truck to a fabricator and see if the tongue could be extended safely.  I chose the tongue extension and am very pleased with the way it handles and the extra room I now have for tight turns.  The fabricator also installed hd weight distribution bars to work with the extension. Debbie
Posted 2008-03-02 2:03 PM (#78481 - in reply to #78450)
Subject: RE: tongue extension
Originally written by dbelling on 2008-03-02 6:59 AM
 http://www.hitchcorner.com/trailer-hitch-accessories.htm
Hitch Extensions
  • Hitch Extensions For 2" Receivers
  • Extends Your Hitch And Still Allows You To Tow
  • You Lose 1/3 Of The Carrying Capacity Of Your Hitch
  • These Extend Your 2" Receiver Out By The Following Lengths:
    7" Extension - Hollow Tube
    <form action=http://www.cartserver.com/sc/cart.cgi method=post>BRHE06...$49.95
    14" Extension - Solid Steel Tube
    <form action=http://www.cartserver.com/sc/cart.cgi method=post>BRHE12...$80.00
    18" Extension - Solid Steel Tube
    <form action=http://www.cartserver.com/sc/cart.cgi method=post>BRHE18...$94.95
dbelling
Reg. Aug 2005
Posted 2008-03-03 4:39 AM (#78518 - in reply to #78481)
Not a hitch extension...This did not seem like a safe option to me.  I had a welder extend the tongue on my trailer.  It seemed with a hitch extension there would be just too much force on that bar.  Maybe it would have worked but I went with the tongue extension just to be safe while pulling horses.  Debbie
Posted 2008-03-03 6:02 PM (#78567 - in reply to #78518)
Originally written by dbelling on 2008-03-03 5:39 AM
How did his BRACE the extension that he welded in??
xyzer
Reg. Apr 2004
Posted 2008-03-03 11:11 PM (#78584 - in reply to #78450)
Debbie,
I would have gone the same way. Either way you are shifting the stress. IMO the longer toung trailer will back nice and ride smoother.
Edited by xyzer 2008-03-03 11:16 PM
dbelling
Reg. Aug 2005
Posted 2008-03-05 5:00 AM (#78675 - in reply to #78567)
I am not sure what your question is about Brace but this is what the fabricator did:  He removed the coupler from the tongue, built the tongue out 12" longer with a solid piece of steel and added the coupler back on.  Also he moved the wd brackets so that I could use them with my existing hitch.  Debbie
Posted 2008-03-06 1:49 PM (#78813 - in reply to #78675)
Originally written by dbelling on 2008-03-05 6:00 AM
If it is just a straight tub of steel out from the frame, without any diagonal cross-supports back to the mainframe, for the extended 12 in...you could actually bend it in a non-linear stressful event,(i.e. the truck and trailer are not in a straight line)
HWBar
Reg. Nov 2005
Posted 2008-03-07 7:54 PM (#78967 - in reply to #78450)
1000100100252525
I would think that any capable fabricator could extend a trailer tounge by 12".
chadsalt
Posted 2008-03-07 8:43 PM (#78970 - in reply to #78967)
1000100100100100
Originally written by HWBar on 2008-03-07 8:54 PM
Easily.  The key word is "capable".
Posted 2008-03-07 8:50 PM (#78971 - in reply to #78450)
Please Post a Photo of the work...
