Pulling with an Astro van
Last activity 2008-03-01 1:15 AM
4 replies, 5867 views
badweather
Reg. Sep 2006
Posted 2008-02-29 1:06 PM (#78336)
Subject: Pulling with an Astro van
I have a 2001 Astro van with a tow package. It is built on a truck chassis. Can I pull a 2 horse bumper pull that weighs 2270 lbs around town and short distances safely? It has electric brakes.
Posted 2008-02-29 1:13 PM (#78339 - in reply to #78336)
Subject: RE: Pulling with an Astro van
A lot of folks here use them to pull their smaller RV's...
http://www.rv.net/forum/index.cfm/fuseaction/listings/forum/41.cfm
canchaser52501
Posted 2008-02-29 3:56 PM (#78365 - in reply to #78336)
I pulled a 2 horse Bp with A GMC Safari several years ago lots of miles with no problems. How the weight is distributed to the tongue of your trailer will make some difference. My BP had a longer tongue so most of the weight was on the wheels. Check your tongue weight and see what the Astro is rated for and you should be O.K.
Posted 2008-02-29 6:15 PM (#78383 - in reply to #78336)
Originally written by badweather on 2008-02-29 2:06 PM
MAKE SURE you have the transmission cooler...I have seen trucks in which the Towng package was ONLY the wiring and the hitch!!!
Roland Hinkle
Reg. Mar 2006
Posted 2008-03-01 1:15 AM (#78405 - in reply to #78336)
I seem to remember Chevy boasting 5,500# towing capacity w/ the Astro.  In addition to the good advice others have offered, check to see at what point you need an equalizing hitch.  Be safe and good luck.
