living quarters installation-walls
Last activity 2008-02-18 10:25 AM
3 replies, 6857 views
kjstewart
Reg. Feb 2008
Posted 2008-02-17 6:56 PM (#77103)
Subject: living quarters installation-walls
What is the best material to use behind 4' x 6' wood wall paneling on an aluminum trailer? I know that Maccwall used furring strips and screws on his and it looked great, but a LQ conversion company that I talked to said that they rivet plywood to the aluminum studs and glue the paneling to the plywood so the screws/nails aren't visible. What about brad nailing onto either plywood or strips-would that hold? Also what are opinions on rivets vs. flat-head sheet metal screws - would rivets hold better? Thanks in advance for the help.
Posted 2008-02-17 9:31 PM (#77122 - in reply to #77103)
Subject: RE: living quarters installation-walls
Finishing nails (brads) by their nature have very small heads. Used alone, they would not be sufficient for the permanent installation of paneling in a trailer. They would, however, work well to hold the paneling in place, while some construction adhesive, applied between the paneling and furring strips dried.
Flat head stainless sheet metal screws, would be a good choice to attach the furring strips. If you were able to find a source of the longer aluminum pop type rivets used by the RV folks, and a pneumatic gun, that would work as well. They have washers that fit under the tail end of a pop rivet, that expands the surface area significantly. It allows a higher grip strength and lessens the chance of a pull out.
BOL  Gard
kjstewart
Reg. Feb 2008
Posted 2008-02-18 7:59 AM (#77135 - in reply to #77122)
Thanks Gard-you always have such good advice! I'm relieved to hear that the furring strips will do fine...I was not looking forward to fitting all that plywood (not to mention the extra weight)!
Posted 2008-02-18 10:25 AM (#77150 - in reply to #77103)
kjstewart
 You're welcome.
There is another matter you may want to consider; the rigidity of the paneling you're planning to install. If the spacing between the studs is wide enough, you will experience some flexation in the paneling if you push on it. The conversion company would lessen this situation with the additional installation of plywood. It would be similar to a sub floor underneath your finish flooring.
You could perform a test to see if you will be satisfied with only the final panel installation. Get a piece of scrap paneling as wide as the studs and temporarily tape it in place. Remember that some areas will be covered with cabinetry, trim pieces, lighting fixtures etc. Other than ceilings, there are few places in a LQ that include large open areas of paneling. You can feel if will work for you, and you can then get a good idea if it is applicable to your desired outcome.
BOL  Gard
