Water Sources...city & tank
Last activity 2008-01-28 11:18 AM
5 replies, 3955 views
Mandi/Abby
Reg. Sep 2003
Posted 2008-01-27 4:18 PM (#75390)
Subject: Water Sources...city & tank
Charter Member
If I hook up to water at a RV spot, is that water routed differently than if my water tank is the source of water for my shower/sink?
greyhorse
Reg. Nov 2005
Posted 2008-01-27 6:40 PM (#75399 - in reply to #75390)
Subject: RE: Water Sources...city & tank
It bypasses your tank and pump, the hookup provides the pressure.
Mandi/Abby
Reg. Sep 2003
Posted 2008-01-28 8:42 AM (#75428 - in reply to #75390)
Charter Member
Awesome!! Thanks.
Do I install anything to keep it from backflowing into the tank/pump or does it have a separate entrance into the water heater?
captclank
Posted 2008-01-28 10:55 AM (#75435 - in reply to #75390)
I would suggest you get a pressure reducer. It just screws on the hose before the city connection. It can be found at any RV store and is cheap insurance. We were at a location that the city water pressure was too high for the LQ water lines and created quite an expensive mess!
greyhorse
Reg. Nov 2005
Posted 2008-01-28 11:08 AM (#75436 - in reply to #75390)
I'm assuming you're installing one of the standard water hookup things, one place to fill the tank and a place a hose screws in to. I think those have the valve built in to them.... hopefully someone will correct me if I'm wrong, never had to mess with that so I'm not 100% how everything works. You'll have to have a valve somewhere.... just don't know where it is.
Edited by greyhorse 2008-01-28 11:11 AM
Mandi/Abby
Reg. Sep 2003
Posted 2008-01-28 11:18 AM (#75438 - in reply to #75436)
Charter Member
Yep. I was planning on one of the water fill hatches for both gravity and city hook up all under one door.
