Flooring in LQ
Last activity 2008-01-22 9:47 AM
3 replies, 4519 views
Mandi/Abby
Reg. Sep 2003
Posted 2008-01-21 7:58 PM (#75013)
Subject: Flooring in LQ
Charter Member
Is there anything that shouldn't be used???
On the DIY personal websites I've looked at, some people have used the tongue & groove type flooring you can purchase at Lowe's, but the friend of our's who came to give me a quote said that because of the movement of the trailer, it doesn't last. Is this true?
I'm afraid with linoleum, it would easily tear and show wear.
classygirl98
Posted 2008-01-21 11:31 PM (#75027 - in reply to #75013)
Subject: RE: Flooring in LQ
100100252525
Since you are doing such a small lq , if it were me i would invest in a very good linoleum. we have had linoleum in our last two lq and have had no problem with tearing or wearing and believe me our trailers get a good work out every season. You can always lay rugs down. I have several down in mine.
HWBar
Reg. Nov 2005
Posted 2008-01-22 6:33 AM (#75037 - in reply to #75013)
1000100100252525
Originally written by Mandi/Abby on 2008-01-21 7:58 PM
I'm affraid that your friend is misinformed, I build most every trailer with the "pergo/armstrong" type tounge and grove flooring, and so does 90% of factory conversion shops. It's tough as nails and I have never seen a negative effect from "trailer movement", It doesn't like alot of water so that may be a factor in your decision.
Mandi/Abby
Reg. Sep 2003
Posted 2008-01-22 9:47 AM (#75057 - in reply to #75037)
Charter Member
Originally written by HWBar on 2008-01-22 6:33 AM
That's what I thought was used in a lot of factory jobs. I don't plan on spilling a lot of water or having a leak issue (either from the trailer or water tanks) so I don't think it would be an issue.
What "movement" does the floor really experience?? I thought with a solid frame and cross beams as the trailer has, there shouldn't be much shifting of the floor...right?
