Adhesive for kick pads?
Last activity 2008-01-22 7:29 PM
9 replies, 9490 views
Towfoo
Reg. Jan 2008
Posted 2008-01-21 12:50 PM (#74956)
Subject: Adhesive for kick pads?
100100252525
What kind of adhesive is best for gluing rubber kick pads to painted steel?
Thanks,
Dan
Posted 2008-01-21 1:02 PM (#74957 - in reply to #74956)
Subject: RE: Adhesive for kick pads?
This might work...  http://www.liquidnails.com/home.do
Towfoo
Reg. Jan 2008
Posted 2008-01-21 1:13 PM (#74960 - in reply to #74956)
100100252525
Which one? None of them specify adhesion to rubber. I see the Builder's Choice 729 is a rubber based adhesive, though. Will that one work on rubber kick pads?
Anyone use this stuff?
http://www.rohmhaas.com/wcm/products/product_detail_f.page?product=...
Edited by Towfoo 2008-01-21 1:25 PM
classygirl98
Posted 2008-01-21 2:32 PM (#74970 - in reply to #74956)
100100252525
I have been thinking about ordering some might putty. It looks like it would be a universal adhesive. Anyone on here used it before? https://www.mightyputty.com/spark/index.php?ai=8
Edited by classygirl98 2008-01-21 2:37 PM
Posted 2008-01-21 4:36 PM (#74988 - in reply to #74956)
A polyurethane glue has very good adhesive qualities to the base metal. A painted surface might degrade the bond somewhat. I've never owned or worked on a trailer with glued on kick panels. All of them have been mechanically fastened.
BOL  Gard
greyhorse
Reg. Nov 2005
Posted 2008-01-21 7:23 PM (#75009 - in reply to #74956)
Use this........... very tough and sticks to almost anything
http://www.austinhardware.com/product.asp?dept%5Fid=478&pf%5Fid=324...
Mandi/Abby
Reg. Sep 2003
Posted 2008-01-21 7:47 PM (#75012 - in reply to #74956)
Charter Member
I had my husband install some thin rubber mats on the inside of my rear tack and on the slant wall of my dressing room on my old metal trailer to prevent a lot of noise related to metal bits banging against the walls. We used rivets to attach them and they held well. We also used them to attach one rubber mat to a wall in the horse area that had been torn off by previous owners.
It worked well, if it is an option for you.
Towfoo
Reg. Jan 2008
Posted 2008-01-22 12:48 AM (#75032 - in reply to #74956)
100100252525
Thanks all. I'll give the Sikaflex polyurethane glue a shot. Looks like it should do the job. I did speak with a chemist at Rohm and Haas about the Thixon product and learned that it isn't feasible because it requires high heat to cure.
Gard, the (presumably) factory kick pads that are on this Logan trailer are both glued and fastened, but they arre coming loose in places, one of which is along the top edge on the gutter side where excrement might get behind it. I can see a tan colored adhesive behind the pads where they have pulled loose. Whatever it is seems to have held up fairly well, considering the trailer's nine years old. There is also a shiny black caulk along the top edge that I'll have to hunt down once the pads are glued back.
Mandi, I plan to do a similar thing with the rear tack for sound dampening, but I was planning to use grey indoor/outdoor carpet like what's in the front tack and just glue it in. I'm trying to avoid putting too many more holes in the steel that might promote rust (previous owner put plenty in it already, LOL).
Thanks again everyone.
Dan
Posted 2008-01-22 8:41 AM (#75045 - in reply to #74956)
Towfoo
Sika also makes a polysulfide caulk/adhesive in colours that could be used to seal the mat edge. This and the 3m5200 are almost industructable.
Mandi/Abby
Reg. Sep 2003
Posted 2008-01-22 7:29 PM (#75090 - in reply to #75032)
Charter Member
Originally written by Towfoo on 2008-01-22 12:48 AM
Mandi, I plan to do a similar thing with the rear tack for sound dampening, but I was planning to use grey indoor/outdoor carpet like what's in the front tack and just glue it in. I'm trying to avoid putting too many more holes in the steel that might promote rust (previous owner put plenty in it already, LOL). Thanks again everyone. Dan
On our new trailer (aluminum) I wanted to decrease the sound in the rear tack as well, but without so many holes so we lined the walls with the white compressed 'stuff' insulation like what we are using for the walls in the front DR, attached with a spray glue (3M Super 77 - good stuff). In spots where the glue wasn't working, I just used the same aluminum tape I had left over from the front insulation project. We then used self taping screws to attach gray commercial grade carpet over that. It turned out way better than I expected. You could probably cut the carpet into smaller sections and attach it directly to the insulation material. I just wanted one large piece (where possible) so we used the screws at each of the support beams.
