Moving an Awning
Last activity 2008-01-10 7:42 PM
2 replies, 3568 views
bechack
Reg. Mar 2006
Posted 2008-01-09 5:52 PM (#74119)
Subject: Moving an Awning
OK, the awning position is just wrong on my trailer.  It is a Carefree Awning.  From looking at it, I can take out the screws at the bottom, loosen what looks like set screws at the top and just slide the thing down the gutter, then reattach the bottom.  Is this all there is to it?  I would really like to get it moved before summer and awning season.
HWBar
Reg. Nov 2005
Posted 2008-01-09 6:22 PM (#74120 - in reply to #74119)
Subject: RE: Moving an Awning
1000100100252525
That's it, just make sure where you are going to re-attach it that the bottom screws have something to bite into. Some aluminum skin trailers, the skin is not enough to support the awning. Also make sure you put the little set screws back in the rail or your awning will slide and roll up crooked.
Edited by HWBar 2008-01-09 6:24 PM
bechack
Reg. Mar 2006
Posted 2008-01-10 7:42 PM (#74185 - in reply to #74119)
Thanks.   Nope, the bottom will screw in to the bottom frame rail.  Should be solid enough.
