Nearly New Kipor 3000 Generator - Gas Leak HELP
Last activity 2007-12-20 6:14 PM
4 replies, 5741 views
Saddlebredlover
Reg. Dec 2005
Posted 2007-12-16 9:20 AM (#72992)
Subject: Nearly New Kipor 3000 Generator - Gas Leak HELP
HI all!
I have a nearly new Kipor 3000 generator that has only been run 3 times.  We live in the midwest and recently had to break it out when we lost power due to the ice.  It ran like a champ, but a day after we stopped using it, it started leaking all the gas out of the bottom.  Has anyone had this same problem?  Please help. Natalee
Posted 2007-12-16 11:19 AM (#72994 - in reply to #72992)
Subject: RE: Nearly New Kipor 3000 Generator - Gas Leak HELP
You'll have to determine from where the fuel is leaking; carburetor, fuel tank, fuel line etc. It may be a loose hose clamp on a fuel line fitting, an offset needle and seat in the carb, or a ruptured fuel line or tank. You will need to look it over and determine where the problem is located, before you can get advise on how to fix the problem.
Wipe the area down with a rag, then you can see where it gets wet again.
DO NOT RESTART the generator until the source of the leak is discovered and repaired and the entire wet area is washed and cleaned.
BOL  Gard
Edited by gard 2007-12-16 11:26 AM
Terri
Posted 2007-12-16 5:00 PM (#73002 - in reply to #72992)
200050010010010025
We had this problem and it was a bad "spring" clamp.  The dealer replaced the clamp and it was fixed.
Dawnya
Posted 2007-12-17 10:52 PM (#73074 - in reply to #73002)
1001001001002525
Originally written by Terri on 2007-12-16 5:00 PM
Wow!  Good to know.... A loose hose would be my guess too.
Mine hadn't been run in a few months so I checked it this past Saturday and it started right up!
Edited by Dawnya 2007-12-17 10:53 PM
Terri
Posted 2007-12-20 6:14 PM (#73226 - in reply to #73074)
200050010010010025
I need to take my camper and generator in.  The generator used to run everything but the microwave at the same time now when just the ac kicks on starts bogging down and trips the breaker.  I think its the camper though because at the fair grounds it tripped the breaker a few times too.  Mice probally ate a wire!!
