Torque And Horsepower, When Is It Enough??
Last activity 2007-11-18 2:46 PM
12 replies, 6798 views
walkin
Posted 2007-11-16 9:59 AM (#71335)
Subject: Torque And Horsepower, When Is It Enough??
500100
So if a truck has a certain GVWR, will the hp, rear, and torque that comes standard handle it??
What is a good hp/torque/ rear combination??  For a 3 horse LQ loaded with a lot of extra water and hay?
Posted 2007-11-16 10:36 AM (#71341 - in reply to #71335)
Subject: RE: Torque And Horsepower, When Is It Enough??
When you're pulling trailers HP figures aren't what brings the bacon home. It's torque; the amount of twist an engine can provide to the drivetrain that's at issue. Quarter mile times are determined by horse power, how large a load a truck can pull over a hill is determined by torque.
Gas engine values are greatly varied, and the numbers are generated at much higher rpms than the diesels, almost twice as high. This means more shifting to keep the rpm in a high range.
Most of the diesels of a few years ago had torque ratings in the 500-550 lb/ft range. Most of the new ones produce 650 lb/ft or better. Not only are these ratings higher than a gas engine, more importantly they are at much lower rpms; typically 1800-2500 rpms instead of a gas at 4000-5000 rpms. This is what reliabily pulls a heavy load comfortably all day long.
Diesels hp and torque values are easily increased with different computer chip installations. An older diesel can be upgraded to match the newer motor's output at a fraction of the price of a new truck.
Any of the diesels available today will pull any trailer within the truck's stated gvwr, and you can hook up to it with no modifications. The only option you might consider is the available rear axle ratio for towing.
BOL  Gard
Posted 2007-11-16 10:57 AM (#71343 - in reply to #71335)
I used to pull what you stated, with 185hp, 385# of torque, with 35" tall tires, 3 speed automatic, 4.10 gears, at 65 mph. Now days it seems to take 350+ hp, 650# torque, 32" tall tires, 5-6 speed automatics, 6 speed manuals, 3.73-4.30 gears and I get passed all the time by those trucks running 75-80 mph. All the new trucks will handle the GVWR stated for said vehicle, how well it handles it depends on how much money you want to spend on said vehicle when purchacing. Just depends on what make, model and style vehicle you want!! They are all good, none better than the other.
Posted 2007-11-16 11:25 PM (#71379 - in reply to #71335)
Here's what you need......well not really, but why not dream...
2007 Freightliner Summit Hauler - $169,283.00
Beautiful M2-112 with Summit Hauler Bed.
VIN#: X97836Stock #: N050
Color: Slate GreyEngine: Cat C13
Transmission: Allison AutoDrivetrain: 4x2
Cab Type: CREW CABSuspension: Air ride
Radio: AM/FM/CD/XM/NAVGVW: 33000 lbs
Amenities: A/C, Cruise Control, Tilt/Telescopic Steering, Power Locks, Power Windows (yes), Air Seats, Jake/Engine Brake
Description: 2007 Freightliner with Custom Bed. Kenwood Navigation System/XM with Speaker Upgrade. Sound system upgrade, Interior floor carpeting with sound deadening package. Custom 17"overhead video system with 2 wireless headphones. Back up camera and monitor. Key less entry system with 2 remotes. Rear view mirror with temp and compass. Complete leather seat upgrade-air ride with power lumbar, heat and dual armrests. Full 5 window tint with brow. Power window and lock switch upgrade. Summit hauler battery saver.
Transwest Truck Trailer RV
7550 E. I-25 Frontage Rd.
Frederick, CO 80516
Phone: (303) 684-3400
Toll-Free: (800) 909-7071
Fax: (303) 684-3401
walkin
Posted 2007-11-17 5:27 AM (#71381 - in reply to #71335)
500100
Thats nice, but not really the answer to the question I asked.
Posted 2007-11-17 12:59 PM (#71388 - in reply to #71381)
Originally written by walkin on 2007-11-17 5:27 AM
Well if you'd post the actual weight we could start to discuss real numbers...
walkin
Posted 2007-11-17 3:26 PM (#71389 - in reply to #71335)
500100
I think they said the GVWR was 19,500
Posted 2007-11-17 3:59 PM (#71390 - in reply to #71335)
Most any of the modern diesel trucks built in the 6-7 years will tow the trailer you decribe.
Of course a 3h LQ might weigh 9,000 or it might weigh 18,000lbs. So you need to be a little more specific.
If I had the heavier trailer, I'd get a dually with the 4.10 rear end. The 9,000 to 11,000lb trailers work fine with a 3.83 SRW
Posted 2007-11-17 4:06 PM (#71391 - in reply to #71389)
Originally written by walkin on 2007-11-17 3:26 PM
Well if they are up around 18000 lbs actual then here are some options...
Well if you go with Ford...you are looking at something like this...
http://www.edmunds.com/insideline/do/Drives/FirstDrives/articleId=119237
GMC C-Series (KODIAK) C4500 is their response...
  • GVWR: 15,000-lbs. (optional on Regular Cab, Crew Cab and Commercial Cutaway models) (Click here for important details)
  • GVWR: 16,000-lbs. (optional on Commercial Cutaway and 2WD Regular Cab models) (Click here for important details)
  • GVWR: 17,500-lbs. (optional on 2WD, Motor Home and Commercial Cutaway models) (Click here for important details)
    http://www.gmfleet.com/pages/submodelOptionalEquipment/2007_Chevrolet_C-Series+(KODIAK)_C4500.jsp
  • Edited by PaulChristenson 2007-11-17 4:45 PM
    walkin
    Posted 2007-11-18 6:18 AM (#71413 - in reply to #71335)
    500100
    No the gvwr on the truck is 19500 I think.  300 hp 860 ft lbs torque.
    mark_4315
    Reg. Nov 2007
    Posted 2007-11-18 9:51 AM (#71423 - in reply to #71389)
    Location: Slightly North of Missouri in the Tall Corn State
    Posted 2007-11-18 1:34 PM (#71430 - in reply to #71413)
    Originally written by walkin on 2007-11-18 6:18 AM
    Well that can pull most most living quarter horse trailers that you'll find for sale...
    I was looking for the weight of the fully loaded trailer, because there are people who pull 18K+ with 350s and they are under trucked in some cases...
    walkin
    Posted 2007-11-18 2:46 PM (#71431 - in reply to #71335)
    500100
    I hear ya.  Thanks.
