Gooseneck with Shortbed
Last activity 2007-10-30 11:16 AM
14 replies, 6253 views
Too L Ranch
Reg. Jul 2006
Posted 2007-10-27 8:27 PM (#70095)
Subject: Gooseneck with Shortbed
I've been pulling with a hauler and now I'm looking at pulling a gooseneck with a Chevy one ton, shortbed. Worried about possible clearance issues when turning tight corners. Don't want to go to a longbed, as the truck is my daily driver. Whatdayathink?
Jeepplr
Reg. Oct 2007
Posted 2007-10-27 9:10 PM (#70098 - in reply to #70095)
Subject: RE: Gooseneck with Shortbed
I am doing it with a Chevy short bed.  I don't have a full width trailer at the front, it is a Lakota, it is a trailer for short beds but still has a bed up front.
Saddlebredlover
Reg. Dec 2005
Posted 2007-10-27 9:46 PM (#70100 - in reply to #70095)
Saddlebredlover
Reg. Dec 2005
Posted 2007-10-27 9:53 PM (#70101 - in reply to #70095)
Oops!  Sorry about the previous post/reply.
I pull a 2006 Exiss with a 2003 2500 Dodge Quad-Cab Ram with a short bed and have no problem.  My mom pulls her Elite trailer with the same type of truck.  It can be done, but you need to be careful turning tight or you will pop the back window of your truck.  My mom did that once with her truck and trailer.  Just be careful and you'll be fine.
giddyupmatt
Reg. Jul 2007
Posted 2007-10-27 10:00 PM (#70102 - in reply to #70095)
Have not had any problems with this one. 07 2500HD 4wd, 6ft bed. Some have said you need a round nose GN. That helps from knocking out back glass when backing.
 And before somebody starts picking the pic apart. This was just a photo op before the hitch was installed and yes the landing gear is on the ground.
Too L Ranch
Reg. Jul 2006
Posted 2007-10-27 11:12 PM (#70103 - in reply to #70095)
Thanks! Just wanted to make sure it would work. Trailer is a Logan with the V'd nose, and have a crash panel on the truck.
headhunter
Reg. Oct 2004
Posted 2007-10-28 6:02 PM (#70122 - in reply to #70103)
50010010025
I pulled my non-LQ Logan gooseneck with a shortbox F350 and had no problems.  Like everybody else has said, just watch the really tight turns.   I bought a LQ trailer and traded out the shortbox F350 for a dually.  But I'd pull a non-LQ trailer with a shorbox again if it the situation came up.
Posted 2007-10-28 6:46 PM (#70123 - in reply to #70095)
Originally written by Too L Ranch on 2007-10-27 8:27 PM
If worse comes to worse..here's a solution...
http://www.mrtruck.net/popup.htm
mingiz
Reg. Jul 2004
Posted 2007-10-29 5:25 AM (#70136 - in reply to #70095)
I have an 06 F250 ext cab sb. I purchased the SB1 extender coupler and now I never worry about having to put it into tight spots or jack knifing it into places. Moves the trailer back about 9inches and doesn't affect the balance and load at all.
barntoys4mom
Reg. May 2007
Posted 2007-10-29 8:57 AM (#70144 - in reply to #70095)
We've pulled Sundowners with a tapered nose for the past 15 years with GMC 3/4 ton short bed and now an GMC extened cab 3/4 ton short bed. My husband raises and plays with bird dogs, so a short bead is a necessity. We also have a custom built aluminum dog box (looks like a fancy tool box) that is designed to fit below the trailer nose that will hold 3 large dogs. I wouldn't have it any other way! Good luck!
Teri
Reg. Sep 2007
Posted 2007-10-29 1:51 PM (#70164 - in reply to #70095)
Me too...I pull with a short bed Ford crew cab 250 deisel. Have never had a problem, but I try really hard not to get myself into any "pickles". Plus I'm an excellent backer-upper which helps. My advice is that: learn how to pull a trailer before you get yourself into a situation where you were wishing you had taken that baby out to the church parking to practice backing up!
Dawnya
Posted 2007-10-29 6:36 PM (#70176 - in reply to #70095)
1001001001002525
Here's my sweet ride.
The trailer has a tapered nose - and that's a must with a short bed!
I've even had to turn it around on a 2-lane highway with no problems!
marym
Reg. Dec 2005
Posted 2007-10-29 8:08 PM (#70188 - in reply to #70095)
I have a 2007 chevy 2500hd Crew cab w/Short box. I pull a 2007 Shadow LQ Trailer. Have backed it (tight turn spots) just like any GN trailer and have not hit the cab. You can't jack knife it of course but you dont do that with any trailer.. Mary
giddyupmatt
Reg. Jul 2007
Posted 2007-10-29 9:33 PM (#70192 - in reply to #70144)
barntoys4mom, you get them jimmys from Davis Pontiac? Thats where that white one up there came from. Wayne is a nice guy to deal with.
barntoys4mom
Reg. May 2007
Posted 2007-10-30 11:16 AM (#70219 - in reply to #70192)
Both trucks and my Yukon XL came from Davis. They also do all our mechanical work. They may be a little higher, but make up for it in service. First Truck lasted 15 years, were 5 years on the second one and five seven years on the Yukon with nothing (knock on wood) but oil changes, etc. You local? Nice truck, hope its good to ya!
