my next question is.........................
Last activity 2007-10-25 3:11 PM
2 replies, 3323 views
july
Reg. Oct 2007
Posted 2007-10-25 1:19 PM (#69990)
Subject: my next question is.........................
now that we have the flooring settled lets move on to the wiring. this tariler came to us with the roof and walls all insulated (walls are glued on) we have an a/c and 1 outlet with 2 plugs, now if we want to add more outlets is it possible to put the wires in conduit pipe and then cover or paint the pipe (maybe the shiney silver would look ok) and just attach the pipes to the walls like i've seen in garages? keep in mind this is not l/q per say, it's more of a fancy dressing room. LOL
greyhorse
Reg. Nov 2005
Posted 2007-10-25 2:43 PM (#69994 - in reply to #69990)
Subject: RE: my next question is.........................
I see no reason you can't do that. Sure would be a lot easier than putting it in your walls since they are glued on. If you don't already have a breaker box I would put one in and wire it through the box, there are boxes made for rv's and lq trailers that have breakers on one side for ac and fuses on the other for dc. Hopefully you already have a box though.
Hank
Reg. Sep 2007
Posted 2007-10-25 3:11 PM (#69997 - in reply to #69990)
Of course you can.  They even make a more decorative wire molding that you can pick up at Home Depot or Lowes.  It's a two-piece molding - half fastens to the wall, you lay the wire in, the snap the cover over it.  They should have all the fittings, too.
