l/q floors
Last activity 2007-10-25 8:23 PM
10 replies, 4875 views
july
Reg. Oct 2007
Posted 2007-10-23 3:43 PM (#69863)
Subject: l/q floors
can i just keep the mats that came with the trailer in the l/q for my floor and put throw rugs over them? we will have no running water and just 4 storage areas that can be moved if needed. can you put linoleum over the rubber mats? do i need to put some sort of water barrier under the rubber mats to keep moisture away from the mats?
crowleysridgegirl
Reg. Apr 2005
Posted 2007-10-23 4:02 PM (#69866 - in reply to #69863)
Subject: RE: l/q floors
2000500100
I doubt that linoleum would adhere to the rubber mats,and they might also be too thick.
july
Reg. Oct 2007
Posted 2007-10-23 6:24 PM (#69867 - in reply to #69863)
can the "floating" laminated wooden floors be installed over the rubber mats?
crowleysridgegirl
Reg. Apr 2005
Posted 2007-10-23 10:36 PM (#69879 - in reply to #69867)
2000500100
I just am not sure.I'd ask a big flooring installer about the surface.I think you can install it over other than plywood,but just don't know about the rubber mats.Laminate wood is pretty in a LQ tho.Pretty indestructible.
Posted 2007-10-24 11:13 AM (#69905 - in reply to #69863)
You can install the "floating" type of wood flooring in your lq if you put down a vapor barrier first. The simple way is a sheet of felt or tar paper. Some flooring systems require the use of a thin padding which is also a vapor barrier.
Some flooring systems lock together with no adhesive, others are glued to each other. None is directly fastened to the underlaying floor.
If the flooring becomes damaged, it is a small enough area to replace at a minimal cost and effort. It can be easily installed in a couple of hours using only a small number of basic tools.
It is a definate DIY type of job and looks great when it's done
BOL  Gard
july
Reg. Oct 2007
Posted 2007-10-24 12:09 PM (#69910 - in reply to #69863)
do i have to take the rubber mats up first? i thought they might be a good insulater??
Posted 2007-10-24 12:47 PM (#69916 - in reply to #69863)
The wooden flooring cannot be installed over the rubber mats. This would also be true of most other flooring materials.
If you want to insulate the floor, you can install wood sleepers, add insulation and a plywood floor and cover with the flooring material of your choice.
BOL  Gard
barrelsnpcs
Posted 2007-10-25 4:34 AM (#69950 - in reply to #69916)
Originally written by gard on 2007-10-24 12:47 PM
BOL  Gard
What are wood sleepers?
july
Reg. Oct 2007
Posted 2007-10-25 5:14 AM (#69951 - in reply to #69863)
i would/need to know what "sleepers" are as well. we want to put this new floor in this weekend.
Posted 2007-10-25 8:46 AM (#69959 - in reply to #69863)
Wood sleepers are pressure treated wood strips adhered to the metal floor, onto which a wood flooring can be attached. Insulation, wiring, and plumbing can be placed between them before they are covered with plywood. The plywood can then be covered with the flooring of your choice.
barrelsnpcs
Posted 2007-10-25 8:23 PM (#70007 - in reply to #69959)
Originally written by gard on 2007-10-25 8:46 AM
Hmmmm, that's interesting. That's the point I'm at right now. I am attaching the "sleepers" to the floor and starting to cut the insulation to go between them. I was wondering where the plumbing and wiring went. Thanks for that information.
