Horse trailer needs to be raised
Last activity 2007-10-08 2:21 PM
8 replies, 6204 views
ddkrueger
Reg. Dec 2003
Posted 2007-10-07 8:28 PM (#68956)
Subject: Horse trailer needs to be raised
Having problems with my Feathertlite trailer going over uneven ground and tearing off exterior plumbing. Is there any way to raise the trailer? We do a lot of primitive camping. Our trailer has torsion axles.
Posted 2007-10-07 8:56 PM (#68963 - in reply to #68956)
Subject: RE: Horse trailer needs to be raised
Originally written by ddkrueger on 2007-10-07 9:28 PM
Is this an issue of Ground Clearance or Breakover Angle?
Edited by PaulChristenson 2007-10-07 8:58 PM
ggrimm01
Reg. Aug 2005
Posted 2007-10-07 9:13 PM (#68967 - in reply to #68956)
Yes, trailer can be raised.   Usually the manufactors does it and the term is called blocking.   Trailers can be blocked 2",3",4" depending on the manufacter.  Paul has it correct about the breakover angle.   Usually the longer the trailer the more you need to be careful.   I have a long Lq trailer and have to watch going into fields, driveways, and areas that have steep angles.
Posted 2007-10-07 10:29 PM (#68972 - in reply to #68956)
If he is tearing off plumbing. That's usually ahead of the axles and would involve Blocking.
Tearing off the bumber would be more symptomatic of Break over
crowleysridgegirl
Reg. Apr 2005
Posted 2007-10-07 11:04 PM (#68977 - in reply to #68967)
2000500100
agreed.We didn't tear off anything,but coming out of our road onto the highway,a steep banked curve that we have to swing out,down,then turn to come back up in our lane,we heard this loud bang,we thought one of the horses had done it.
Wrong.
When we arrived,I walked between truck and trailer under GN,and   I SAW what the loud bang had been.It had been the GN hitting the rear left corner of the tailgate as we turned to come back up into our lane!@@$#%%!
So now,we go out a different direction.
ddkrueger
Reg. Dec 2003
Posted 2007-10-08 5:58 AM (#68984 - in reply to #68963)
Our trailer is 30 ft. on the floor. Sounds like I need to have the trailer blocked. Does anyone know who can do this, or do I need to take the trailer to the manufacturer?
Tx. Vaquero
Reg. Jun 2006
Posted 2007-10-08 7:34 AM (#68986 - in reply to #68984)
Axle blocking is usually accomplished by adding square tubing between the trailer frame and axle frame. A good welding shop can do it, just make sure they get the axle allignment right with good measurement of axle position before and after. Be cautious about how much you raise the trailer, as the step down for your horses can be a problem if too high, with the potential for a back leg to slip under the trailer if the surface is slick.
Posted 2007-10-08 2:16 PM (#69009 - in reply to #68986)
Originally written by Tx. Vaquero on 2007-10-08 8:34 AM
Tx Vaquero gave you the right skinny...
Just a re-emphasis on making sure your axles are still true after the raise...or tire complaints will be your next set of posts on this forum...
Edited by PaulChristenson 2007-10-08 2:18 PM
Posted 2007-10-08 2:21 PM (#69010 - in reply to #68977)
Originally written by crowleysridgegirl on 2007-10-07 12:04 AM
Wrong.
Before I got the flatbed...I would routinely leave my tailgate at home when I towed with the pickup...just because of what you encountered......by the way you can hardly see it in my tailgate...yeah right...
