Side marker lights on a 2003 Sundowner
Last activity 2007-09-24 2:25 PM
2 replies, 4531 views
dogman
Reg. Sep 2007
Posted 2007-09-22 8:51 PM (#68268)
Subject: Side marker lights on a 2003 Sundowner
One of my side marker lights (on fender) on my Sundowner is out.  How do you change these?  The cover is rivited onto the trailer.  Can you change a bulb or do you need to change the whole assembly?  Thanks in advance.
Posted 2007-09-22 9:33 PM (#68269 - in reply to #68268)
Subject: RE: Side marker lights on a 2003 Sundowner
Your's may be different...  The base is held in place with  rivets or a threaded stud.  The actual light bulb is inside a sealed plastic housing that plugs into the base.  Some housings are standard truck parts.  (long narrow style)  Others seem to be available only at a Sundowner dealer. (Short square style with offset pins)
giddyupmatt
Reg. Jul 2007
Posted 2007-09-24 2:25 PM (#68327 - in reply to #68268)
If you are lucky its probably just not grounded good cause them little boogers is right exspensive for no more than they are. I drilled the rivets out of mine and put screws in them and they lit right back up. Seems like they are grounded through the rivets and the work loose and get dirty.
