How strong should butt bars be????
Last activity 2007-09-23 4:10 PM
11 replies, 6142 views
prospect
Reg. Sep 2007
Posted 2007-09-20 4:02 PM (#68183)
Subject: How strong should butt bars be????
IMO - butt bars should be strong enough to hold the full weight of a horse, just in case they need to, for basic safety reasons.
I recently purchased a brand-new all-aluminum trailer.  I hauled my three-year-old up to work with my trainer.  When I unloaded him, I found that the plate to which the butt bar attaches was pulling out of the wall of the trailer.  Apparently, my horse was sitting on the butt bar, and, apparently,  it was not attached to anything solid.
 I am very disturbed by this.  I think it is a major design issue that impacts safety.
dawnb
Posted 2007-09-20 4:28 PM (#68184 - in reply to #68183)
Subject: RE: How strong should butt bars be????
have you talked to the dealer from where you bought the trailer? If it is brand new there is warranty. Maybe someone at the factory forgot to finish installing the butt bar.
prospect
Reg. Sep 2007
Posted 2007-09-20 4:49 PM (#68186 - in reply to #68183)
It is being repaired under warranty.  That does not mean that it is not a serious safety issue.
horsey1
Reg. Dec 2004
Posted 2007-09-21 10:16 AM (#68216 - in reply to #68183)
My draft horse friends won't use butt bars because they say they are always being bent.... They use nylon straps. Anyonbe else out there have an opinion??
Posted 2007-09-21 1:02 PM (#68227 - in reply to #68216)
Originally written by horsey1 on 2007-09-21 11:16 AM
Better to have a bent butt bar than a damaged rear door assembly...I've own and have hauled draft horses...Never lost a butt bar......My guess is that your friends have TOO LARGE a compartment for their drafts, which allows them to step back into the bars...
horsey1
Reg. Dec 2004
Posted 2007-09-21 3:20 PM (#68235 - in reply to #68183)
Okay Paul, now I'm confused... Small stalls won't let a draft sit on a butt bar, but large ones will? Please explain. The bent bars I've seen bent are in regular straightload stalls.
Posted 2007-09-21 10:04 PM (#68255 - in reply to #68235)
Originally written by horsey1 on 2007-09-21 4:20 PM
If a Draft Horse has room to move Back and Forth in a straightload...that is when they get bent...Visualize their mass moving backward a foot and then hitting the butt bar...
The event is a 1 foot/ton event...quite a bit of energy for the butt bar to absorb...
reinergirl
Reg. Feb 2007
Posted 2007-09-22 9:29 AM (#68260 - in reply to #68183)
I always assumed that a "butt bar" should be just that - a bar and assumed that the nylon straps were just a cheap shortcut. But after I asked a few questions of manufacturers, there is a reason they moved to using a nylon strap.
From what I understand, the nylon strap is supposed to safer than the bar. It won't bend and if a horse gets caught up under one, you can cut the strap with a knife.
Not saying I agree, just repeating what I was told.
horsey1
Reg. Dec 2004
Posted 2007-09-22 10:29 AM (#68261 - in reply to #68183)
And you'll not have an extra foot in between a Belgian and the rest of the stall. Usually just a very few inches at most....
Posted 2007-09-22 2:59 PM (#68263 - in reply to #68260)
Originally written by reinergirl on 2007-09-22 10:29 AM
Well if a Draft could get under a butt bar...I would be greatly impressed...
Can you say LIMBO...HOW LOW CAN YOU GO???...
AbbyB
Posted 2007-09-22 4:30 PM (#68264 - in reply to #68183)
When I got my 3H slant, it did not have ANY butt bar, etc.  I enstalled 2 eye bolt - one on the curb side of the rear of the trailer & the other on the back tack wall.  Then got strong snaps & attached a chain, which I covered w/the insulation tube you put over pipes.  It has work great....never had a horse get stupid w/one, but this reminds any that might get in a yank to get out, that there is a barrier.
leekirk711w
Posted 2007-09-23 4:10 PM (#68286 - in reply to #68183)
Edited by leekirk711w 2007-09-23 4:12 PM
