Refridgerator!
Last activity 2007-09-21 7:57 AM
4 replies, 3960 views
Grizzly2k1
Reg. Apr 2005
Posted 2007-09-19 3:01 PM (#68109)
Subject: Refridgerator!
I have a Domestic Refridgerator with freezer! its about 6 to 6.5 cubic ft. The proble I'm having it the refridgerator is freezing everything! I can't find a thermostat on it anywhere! any help would be great!
greyhorse
Reg. Nov 2005
Posted 2007-09-19 3:41 PM (#68113 - in reply to #68109)
Subject: RE: Refridgerator!
Should be able to go to the Dometic website and look up your model and find out how to adjust it.
bechack
Reg. Mar 2006
Posted 2007-09-19 3:44 PM (#68114 - in reply to #68109)
If it is a newer one, there is no thermostat. It is factory preset! Argh! Call Dometic, there might be a way to adjust it from outside, not sure. Also, double check for level. Do you have a little inside fan to circulate the cold air so you don't have hot and cold spots. They work really really well. Are you running off Propane or electric?
Candy girl
Reg. Apr 2006
Posted 2007-09-21 7:53 AM (#68205 - in reply to #68109)
Candy girl
Reg. Apr 2006
Posted 2007-09-21 7:57 AM (#68206 - in reply to #68109)
I have a Dometic frig in our 1999 LQ.  There's no thermostat, per se, but there is a button to press and a light bar on the front at the top to make it colder and warmer.
Here's a picture, albeit not that good, that shows the "light bar".  I'll try to get a better pic this weekend.
DSC06124
