Ceiling removal
Last activity 2007-09-16 4:00 PM
1 replies, 3792 views
racesarabhorses
Reg. Oct 2005
Posted 2007-09-16 3:35 PM (#67991)
Subject: Ceiling removal
I want to remove the ceiling from the trailer in my sig, so that I can cut skylights, replace insulation with something more suited to the task, and replace the ceiling material. The material used currently is some sort of plastic RV-style junk that looks like white ice, held in place with rivets.
How would I go about removing this? I assume I could just cut it out with an X-Acto knife, then Dremel the rivet heads off. Does anyone know if I could then remove the back side of the rivet? I don't know what the stuff is fastened into on the other side.
Thanks,
Mike
Posted 2007-09-16 4:00 PM (#67995 - in reply to #67991)
Subject: RE: Ceiling removal
Just use a 1/8" drill bit and drill out the pop rivets, use a short bit.......like, 1/2" long so you don't poke through the roof metal. After drilling out the rivets the metal strap cross bows and the panels will just fall out. I don't think they are attached on the sides. Those metal bows are all that's holding the panels up on our Silver Star.
Edited by retento 2007-09-16 4:03 PM
