Gas Mileage While Towing?
Jump to page : 1 2 3
Now viewing page 3 [25 messages per page]
Last activity 2011-06-27 12:56 PM
64 replies, 22525 views
Tx. Vaquero
Reg. Jun 2006
Posted 2007-09-15 8:04 AM (#67913 - in reply to #67900)
Subject: RE: Gas Mileage While Towing?
goodyear 215/17.5 rated 75 mph by goodyear, will handle extended runs above 80, no problem
chadsalt
Posted 2007-09-15 3:41 PM (#67939 - in reply to #67913)
1000100100100100
Originally written by Tx. Vaquero on 2007-09-15 9:04 AM
is that a ST215/17.5 ??  im pretty sure ST tires are no larger than 16".  17.5" should be in the truck class, not ST or the LT (light truck).
Edited by chadsalt 2007-09-15 3:42 PM
Posted 2007-09-15 4:12 PM (#67940 - in reply to #67510)
Here are all of Goodyear's RV and Trailer tires
http://www.goodyear.com/rv/products/
Tx. Vaquero
Reg. Jun 2006
Posted 2007-09-15 6:06 PM (#67944 - in reply to #67510)
The 17.5 is ONLY a trailer tire, and yes Paul, it is made by Goodyear. My new Elite came with them, and they are rated for 75, but I have run 80 plus for several hours on I-10 between Phoenix and San Antonio with 19,000 on the trailer and no problems. Generalizations are what get you in trouble. The good thing about the 17.5 is that the diameter of the tire is the same as a 230/80-16, so you can interchange if you loose one and don't have a spare. Paul, since you are into spec. sheets, look on the Goodyear web site under loads/tire pressures and you will find the 17.5. Chad, they won't work on your 2 horse, but they will interchange with most 8 lug 16" wheels. I'm running 130# in mine.
Posted 2007-09-15 6:17 PM (#67945 - in reply to #67510)
My 17.5, 8 lug wheels have 5/8" stud/lug holes, whereas my 16", 8 lug wheels carry a 9/16" stud/lug holes, the pilot hole in the rim is larger on the 17.5's, so some of these wheels may not enterchange.........Or at least they won't on anything I got here in the yard.
Tx. Vaquero
Reg. Jun 2006
Posted 2007-09-15 6:25 PM (#67946 - in reply to #67510)
Yeah Retento, I know you are right, they won't fit on all of them, but they will on some. How do you like yours? I think they are the best improvement in tires in a long time. Are yours Goodyear?
chadsalt
Posted 2007-09-15 8:09 PM (#67955 - in reply to #67944)
1000100100100100
Originally written by Tx. Vaquero on 2007-09-15 7:06 PM
i dont see where you answered my question.  i understand it is a trailer tire, but does it say ST before the size?  if it does not have ST then it is not the type of tire paul and I are talking about. the 17.5" tires in the load/inflation chart i have are NOT ST tires.
Edited by chadsalt 2007-09-15 8:11 PM
Posted 2007-09-15 8:14 PM (#67957 - in reply to #67944)
I went to the Goodyear site...and the load inflation data they have is massively out of date 2005/2006...
http://www.goodyear.com/rv/pdf/rv_inflation.pdf
And the only tires that had inflation rates of 130 psi were 22.5" tires
These Elites sound like great tires...I wonder why Goodyear doesn't have them on their website???
What is the ballpark per tire?
And do you need special rims, like the Goodyear UnisteelĀ® G614 RSTĀ®???
Edited by PaulChristenson 2007-09-15 8:20 PM
chadsalt
Posted 2007-09-15 8:23 PM (#67958 - in reply to #67510)
1000100100100100
never mind, according to this.........
the tire size you are talking about is NOT an ST tire.  that explains why yours are rated at 75 mph.
Tx. Vaquero
Reg. Jun 2006
Posted 2007-09-15 8:51 PM (#67959 - in reply to #67510)
Elite is a trailer, not a tire. I think the only thing you guys know for sure is that a 9/16 stud will fit in a 5/8 hole.
Posted 2007-09-16 2:07 AM (#67967 - in reply to #67959)
Originally written by Tx. Vaquero on 2007-09-15 9:51 PM
Then why don't you enlighten us and tell us what the model of the tire is????
Posted 2007-09-16 9:38 AM (#67973 - in reply to #67510)
Tx. My 17.5 tires were made in .......CHINA!!!! "Duratrac" model "ST-990",  215-75R-17.5, LR-H, 16pr,  rated 4880# at 125psi, and they are regrooveable. It don't say what the speed rating is anywhere on the tire, most of the time I don't get much over 65 mph with them anyway. They will dry rot and explode before I'll ever wear them out.
Edited by retento 2007-09-16 3:55 PM
Posted 2007-09-16 3:47 PM (#67992 - in reply to #67973)
Originally written by retento on 2007-09-16 10:38 AM
Tx. My 17.5 tires were made in .......CHINA!!!! "Duratrac" model "ST-990",  215-75R-17.5, LR-H, 16pr,  rated 4880# at 125psi, and they are regrooveable. It don't say what the speed rating is anywhere on the tire, most of the time I don't get much over 65 mph with them anyway. They will dry rot and explode before I'll ever were them out.
They aren't one of the Chinese recalled tire models are they???
Edited by PaulChristenson 2007-09-16 3:55 PM
Posted 2007-09-16 3:53 PM (#67993 - in reply to #67510)
Paul, I have not seen that brand listed anywhere as be recalled. I'm keeping my fingers crossed. Those 17.5, LR-H tires run around $250.00 each........Four on the ground plus the spare, that adds up pretty quick.
Canoeswamp
Reg. Jun 2011
Posted 2011-06-27 12:56 PM (#135203 - in reply to #67510)
I asked my horses if they liked it when I drove fast, and they said, "Neigh."
