refrigerator not working
Last activity 2007-08-22 10:49 AM
4 replies, 3570 views
badweather
Reg. Sep 2006
Posted 2007-08-21 6:58 PM (#66209)
Subject: refrigerator not working
Our refrigerator is cooling in the freezer great but its not working in the refrigerator compartment. Checked the fuses. Its the gas and electric kind. Anyone know what I could check?
soundhorse
Reg. Aug 2006
Posted 2007-08-21 7:26 PM (#66210 - in reply to #66209)
Subject: RE: refrigerator not working
We just had the same problem. Bottom line, the conversion company failed to put in enough vents for the refrigerator to cool properly. The freezer worked well but the refrigerator would only get down to 50 degrees on the coldest setting.
greyhorse
Reg. Nov 2005
Posted 2007-08-21 7:50 PM (#66212 - in reply to #66209)
Is it frosted up? Might try turning it off for several hours, leaving the doors open to let it defrost and then see what happens.
ggrimm01
Reg. Aug 2005
Posted 2007-08-21 9:15 PM (#66217 - in reply to #66209)
One thing you can do is get the maintenance manual here on the net and run through the diagnostic.  I had a probem with are norcold and narroed it down to the circut board.
canchaser52501
Posted 2007-08-22 10:49 AM (#66261 - in reply to #66209)
I had a similar problem and when it was installed, they did not drop the refrigerator down low enough away from the vent so that the heat will escape. They put a 12 volt fan that kicks on automatically that helps move the heat away from the refrigerator and out the vent. Otherwise it gets too hot and starts to defrost itself. When it was cool outside this spring it worked fine, but I started having problems when the weather got really warm.
Good Luck!
