prepping truck for gn
Last activity 2007-08-16 8:31 PM
10 replies, 4758 views
leekirk711w
Posted 2007-08-13 6:42 AM (#65698)
Subject: prepping truck for gn
My truck is set up to tow a BP trailer - I am planning to get a gooseneck. It has a cap and a rubber mat in the bed. Obviously, I have to lose the cap. I am concerned about protecting the truck bed.
Should I get a spray-in bed liner after I get the GN hitch installed? What kind of bed cover can be used with a gooseneck? One that rolls out of the way or other options?
Posted 2007-08-13 7:00 AM (#65700 - in reply to #65698)
Subject: RE: prepping truck for gn
First question... Can your truck handle the weight of the GN trailer you are considering ?
Since you're used to a cap, you might be better pleased with a roll up cover.  It protects the contents from the weather and untrust worthy eyes.
laxpatrick
Posted 2007-08-13 7:18 AM (#65702 - in reply to #65698)
We have one of the Advanced Folding Covers - works great with the gooseneck and keeps things under lock and key when needed.
As far as the bedliner - personal choice.  I recently had Line-X put it and I'm absolutely thrilled with it.  The bed mat is now in the garage...
LAXPatrick
leekirk711w
Posted 2007-08-13 8:36 AM (#65704 - in reply to #65700)
I think I have plenty of truck - 3/4 ton 2001 Dodge 4wd heavy duty everything. I am getting a 2h GN with DR, no LQ.
I am looking to protect the contents from the weather and the bed from rust and other damage.
Dunoir
Posted 2007-08-13 10:56 AM (#65720 - in reply to #65698)
50010025
I got the Rhino-liner and love it.  I had them spray it on and then got the popup GN hitch installed.  The rolloden bed covers are very nice, but pricey and of course you have top have it open when using the GN.
   The spray is far superior to the bed liners that drop in especially with a GN hitch as water will get under the liner and can rust out the bed.
headhunter
Reg. Oct 2004
Posted 2007-08-13 4:12 PM (#65753 - in reply to #65698)
50010010025
The spray on bedliners (Line-X, Rhinoliner, etc) are way better than the drop in liner shells.  My last truck had the liner shell when I bought it and it was so slick you couldn't stand up or walk around in the truck bed. Took it out and had the spray in bedliner put in.
rick
Posted 2007-08-13 8:46 PM (#65771 - in reply to #65698)
I would go with the sprayed in bedliner and a roll up if ya want to keep things dry w/o gooseneck.
Just for comparison Rhinoliner is more rubbery and more rough, line-x is more smooth and a little harder, I have Rhino in personal truck and line-x in work truck. I think I like Rhino better stuff doesn't seem to slide, some stuff slides on line-x.
rick
Posted 2007-08-13 8:48 PM (#65772 - in reply to #65698)
Posted 2007-08-14 10:59 PM (#65864 - in reply to #65698)
You may be adding Supersprings depending on the GVW of the trailer...
SLICKRNSNOT
Reg. May 2006
Posted 2007-08-15 10:07 PM (#65933 - in reply to #65698)
I had  4 horse gooseneck with dr and My 3/4 ton pulled it just fine.You should not need any extra springs.
N2ridin
Posted 2007-08-16 8:31 PM (#65969 - in reply to #65698)
50010025
I pulled a 3 horse 8' wide 12' short wall LQ with a 2002 GMC 2500 HD.  It squated pretty good when we brought the trailer home.  Immediately put on a set of Superspings, and it sat level even when loaded with horses and "stuff".  It did make the ride on the truck much stiffer, but it was worth it to have the truck level with the big trailer.  I wish I could sell those spings.
