Champion generators
Last activity 2007-08-10 1:47 PM
11 replies, 5642 views
barrelsnpcs
Posted 2007-08-06 10:17 PM (#65294)
Subject: Champion generators
Anyone have one of those Champion 3500 generators that is a Honda knockoff? Are they loud?  Any problems with it?
Spooler
Reg. Aug 2006
Posted 2007-08-07 1:51 PM (#65333 - in reply to #65294)
Subject: RE: Champion generators
50025
I have one and yes it is on the load side.  An inverter type would be much quieter but for the money the Champion works great. No issues with mine. If you have the money get a Kipor, Yamaha, or a Honda inverter generator.  They are about 2000 dollars.
Posted 2007-08-07 2:43 PM (#65337 - in reply to #65294)
 I got a Yamaha EF3000iSEB.
barrelsnpcs
Posted 2007-08-07 5:09 PM (#65346 - in reply to #65333)
Thanks for the reply.  That's the whole problem,..I can't really justify spending $2000 for something that I won't use that often. I have heard and read good things about the Champion but wanted to hear from people that actually use them or have heard them. What all can you run with it? ( A/C, microwave, etc?)  How long will the A/C run on a tank of gas?
Originally written by Spooler on 2007-08-07 1:51 PM
Spooler
Reg. Aug 2006
Posted 2007-08-07 5:30 PM (#65347 - in reply to #65294)
50025
I meant the loud side but not as loud as most.  Run the A/C and everything else just not the A/C and the Microwave at the same time because it is a 3500w. Haven't spent the night in it yet but it will run overnight on a tank from what I have read on RV.net. A couple more people on here have them. The reason I bought this one was also because of cost and the amount I will use it. I wasn't going to spend 2000 dollars that's for sure.
jdzaharia
Reg. Apr 2006
Posted 2007-08-08 12:57 PM (#65432 - in reply to #65294)
1001001001002525
I have the Champion 3500W generator.  I was actually pleasantly surprised by the noise level the first time I started it up.  But, I do not camp with it, either.  I use it for projects around my place where it is handier than multiple extension cords.  I have used it in weather from -15F to 95F and always has started on the first or second pull.  I have probably 50 hours on mine and have been also pleasantly surprised with the fuel consumption.
Why do you say they are a Honda knockoff?  I would say that nothing about mine resembles a Honda, except that electricity comes out of the plug, just like the Honda.
Terri
Posted 2007-08-08 3:27 PM (#65442 - in reply to #65346)
200050010010010025
I paid $1100 for my kipor when I bought my RV.  I know there are others on here that have paid less on line.
Bgdddyrch
Posted 2007-08-09 12:53 PM (#65489 - in reply to #65333)
Can anyone describe what an "inverted" generator is?
We just bought our first LQ trailer and we need to get a generator. Very surprised at the high cost. Everyone loves the Honda so thanks for telling us that the Yamaha and Kipor is also a quiet unit.
Also, has anyone heard of a place where you can buy refurbished or remanufactured units?
Terri
Posted 2007-08-09 3:25 PM (#65502 - in reply to #65489)
200050010010010025
The inverter generators are the ones that have a constant power out put and are safe for electronics.  TV, DVD players, computers and such.
Posted 2007-08-10 6:40 AM (#65542 - in reply to #65489)
Originally written by Bgdddyrch on 2007-08-09 11:53 AM
Can anyone describe what an "inverted" generator is? ?
Actually the term is "inverter"   An inverter is an electronic circuit that converts direct current (DC) to alternating current (AC).  The generator is used to produce Direct Current that the inverter circuit uses to make the 120 volt 60 cycle Alternating Current your TV, microwave, etc uses.  The DC generator doesn't have to run at 3600 rpm or some multiple of 60 like most generators/alternators do.  Therefore it can run slower and quieter.  The inverter circuit can also be a cleaner source of power for electronics since the output frequency doesn't change with engine speed...
Bgdddyrch
Posted 2007-08-10 10:28 AM (#65553 - in reply to #65542)
Holey Moley, that was a good answer HossPuller.
Where are you from in NC? I live in Lexington just south of W-S.
Posted 2007-08-10 1:47 PM (#65573 - in reply to #65553)
Originally written by Bgdddyrch on 2007-08-10 9:28 AM
Holey Moley, that was a good answer HossPuller. Where are you from in NC? I live in Lexington just south of W-S.
Thans ...  Sent you a PM
