What is the most quiet generator
Last activity 2007-07-27 3:53 PM
8 replies, 5478 views
Ruth
Reg. Oct 2005
Posted 2007-07-24 10:14 PM (#64362)
Subject: What is the most quiet generator
We are considering buying a generator for our living quarters to use when we camp. What is the most quiet one on the market. Thanks, Ruth
crowleysridgegirl
Reg. Apr 2005
Posted 2007-07-24 11:14 PM (#64363 - in reply to #64362)
Subject: RE: What is the most quiet generator
2000500100
Onan generators are usually one  of the quitest.
threeman
Posted 2007-07-25 5:45 AM (#64365 - in reply to #64363)
10010010025
If you dont need anything over a 3000 watt generator I honestly would buy the Yamaha 3000Si boost(?)  A friend of mine has one and its been used really hard.  Nothing but periodic maintenance is all its had.  In my opinion it sounds like a 12v air compressor.  He used it in the bed of the truck just pulled out from underneath the trailer tongue and fired it up.  I can't remember how many hours it ran on tank of gas but it was really long time for small tank.  It also was alot quieter than the 4000 Onan that I had.  if you need something bigger I would go with  Onan/Honda.
Rich M.
Posted 2007-07-25 5:55 AM (#64366 - in reply to #64362)
Generally, " Inverter" type generators are the quietest. Honda,Yamaha,Kipor all within a few db. of each other and regarded as very quiet. I have a Yamaha, most are suprised to find it is even running. Rich
j&j
Reg. Oct 2005
Posted 2007-07-25 6:51 AM (#64369 - in reply to #64362)
We just got a Honda 3000EU and are amazed at how quiet it is. It is big enough to fire up our 13,500 AC unit. All camping type generators are rated for decibels so you can compare. This one is rated 48-58 Db. It also only weighs 134#, so is easy to move around.
j&j
Terri
Posted 2007-07-25 12:30 PM (#64381 - in reply to #64369)
200050010010010025
When comparing the generators, you have to look carefully at the rating.  You may have two that are 65db but then one could be from 10ft and the other from 20ft.
maccwall
Reg. May 2004
Posted 2007-07-27 1:36 PM (#64491 - in reply to #64381)
500
Maybe this will help save you some time:
jd&ez
Posted 2007-07-27 2:17 PM (#64493 - in reply to #64362)
Originally written by Ruth on 2007-07-24 10:14 PM
It's going to depend on the size of the generator you need also. The 3000 watt ones are pretty quiet, but, they won't run everything in an LQ. I borrowed a friend's Honda 3000 while our Onan was in the shop. We would have to turn off the AC to use the microwave and coffee maker or it would kick the breaker.
We have found that quietness in a generator at horse shows is overrated as the quiter our's is, the more we can hear other people's noisy generators.
Paints
Posted 2007-07-27 3:53 PM (#64496 - in reply to #64362)
Honda Ya does cost little more BUT well WORTH the money....Is very very very quiet....Is highly recommened in parks because so quiet.
