Battery & inverter
Last activity 2007-07-11 8:21 PM
7 replies, 4454 views
sorrelrider
Reg. Mar 2007
Posted 2007-07-11 8:34 AM (#63647)
Subject: Battery & inverter
I am totally not sure what I am doing here, but my question is,if I hook a convertor to a deepcell battery could I run lights,tv,micro,fans,appliances,etc with a set up like that? I understand NOT all at once.How big of a convertor do I need?Or am I way off base on this??
Thanks....
laxpatrick
Posted 2007-07-11 9:09 AM (#63650 - in reply to #63647)
Subject: RE: Battery & inverter
Can you? Sure. The size of the inverter is dictated by the load you'll be demanding and the available battery power. Most inverters have appliance size guidelines listed - let that be your guide unless you want to do some math and figure load and demand.
Lights and say a small TV should be ok with a 400 watt. The microwave may demand more than that - folks that are using those or feel like running the numbers can chime in. We use our little inverter for the horsey light string and not much more, lol.
Here's an article you may find helpful:
http://www.roadtripamerica.com/dashboarding/Power-Inverters.htm
LAXPatrick
Candy girl
Reg. Apr 2006
Posted 2007-07-11 11:52 AM (#63663 - in reply to #63647)
We just bought a 400 watt inverter because the description said it could run small TV and video game console.  We don't have a horse for our son so we bought the inverter for him to keep busy while we're riding when we don't have electric hook-ups.  I'll let you know how it works out.
 I have to ask........where can I find string horsey lights??  I want some!!
Edited by Candy girl 2007-07-11 11:54 AM
Rostrenga
Posted 2007-07-11 12:38 PM (#63666 - in reply to #63647)
I guess my question is: If I hook up an inverter an plug in my Mr. Coffee, how long before my batteries are dead. How fast does an inverter drain deep cycle batteries?
laxpatrick
Posted 2007-07-11 1:35 PM (#63674 - in reply to #63647)
That depends - on how many watts the coffee maker draws. There's no way to calculate as the wattage draw would vary depending on the brew cycle... I'd hope that we'd be able to avoid the math discussion, but here goes. Amps = watts/volts (need to also take into consideration the inverter's efficiency rating - you might lose 10% there) Brewing, a given coffee maker needs 1250 watts - 200 to keep the joe warm. Figure using it for 20 minutes, that's 41.7 Amp Hours. I'd imagine that your batteries wouldn't last long, even with a big enough inverter... In general, power hogs like microwaves and coffee pots are best run with generators or shore power.
KDL
Reg. Oct 2005
Posted 2007-07-11 5:12 PM (#63687 - in reply to #63663)
You can get the "string horsey lights" at Camping World and I have even seen them at Tractor Supply, but it was at Christmas time.
laxpatrick
Posted 2007-07-11 5:55 PM (#63691 - in reply to #63647)
Googled it, though I think we got ours from Valley Vet:
http://www.offthedeepend.com/c-30-western.aspx
Some different ones: http://www.amazon.com/Horse-Lovers-10-ft-String-Light/dp/B000Q62O02
LAXPatrick
Candy girl
Reg. Apr 2006
Posted 2007-07-11 8:21 PM (#63702 - in reply to #63647)
Thanks everyone for the help with the horsey string lights. Sorrelrider....sorry to hijack your thread. Good luck with your inverter.
Edited by Candy girl 2007-07-11 8:22 PM
