Port Gen Aux Fuel Tank
Last activity 2007-06-24 7:01 AM
4 replies, 3511 views
roan critter
Reg. Sep 2003
Posted 2007-06-21 6:00 PM (#62617)
Subject: Port Gen Aux Fuel Tank
Expert of all Expert...
Who has an auxiliary tank for their portable generator? What do you use? Where' d you get it, etc.?
I keep my generator in the bed of my pickup. Really annoying when running to to power AC 24/7 for a couple of days straight to have to refill the gas tank every 8-10hrs. I remember seeing something a year or so ago where someone had made a gravity fed one from a 10gal marine tank, but I can't seem to find the information again.
All help is appreciated.
DaveM
Reg. Sep 2003
Posted 2007-06-22 11:15 PM (#62679 - in reply to #62617)
Subject: RE: Port Gen Aux Fuel Tank
I'll bump this up and ask around. Too bad you can't get a direct feed from your truck tank . . assuming of course that you have a gas tank and not a diesel.
Oh, hey.  I found this on Ebay.
Feeds ONE Generator
Models:
Honda
EU1000iA2 and EU2000i
Yamaha
EF1000isc,
Robin
R1100 and R1700i
- Holds 6 gallons of gas.
Dimensions: 20"L x 11"W x 12"H
Unit sits level with generator. No elevation needed.
Incredible!
This auxiliary tank can extend the
full-power output of your generator up to 30+ hours!
The Duration Tank can be filled before your adventure
and is completely safe for travel when full of fuel. It is easy
to use: simply disconnect your generator's cap, screw in
the special adapter and connect to the Duration Tank
which is DOT and USCG approved. Total installation time:
3 minutes. This tank adds 6 gallons to your gen's one
gallon tank and allows you to run for 7 times what you
would normally do with the internal tank alone. Great for
keeping the fridge cold all day and night, or for a weekend
at the cabin where no one will need to refill the generator's
tank the whole time. Unit is safe for travel or storage when
full of fuel with shutoff valves in fuel lines and cap
breather. Simply disconnect your generator's fuel cap,
screw in the adaptor and connect to the Duration EU Tank.
US $109.99
Snickers
Posted 2007-06-23 10:02 AM (#62694 - in reply to #62617)
Dave beat me to the info. Not sure what make gen you have but if you do a search for that make you might find something that would work. If you happen to have the Honda then check out www.wisesales.com They offer a single feed model and also one that will supply two gens.
roan critter
Reg. Sep 2003
Posted 2007-06-23 5:42 PM (#62713 - in reply to #62694)
Dave, Have I told you lately that I love you? Of course not, Gail scares me, but the sentiment is there & you get the idea.
THANK YOU!!!
DaveM
Reg. Sep 2003
Posted 2007-06-24 7:01 AM (#62734 - in reply to #62713)
Originally written by roan critter on 2007-06-23 5:42 PM
Dave, Have I told you lately that I love you? Of course not, Gail scares me, but the sentiment is there & you get the idea. THANK YOU!!!
 YM
