Unusual tire wear on trailer?
Last activity 2007-06-04 9:17 PM
3 replies, 3400 views
ksCowgirl78
Reg. Jun 2005
Posted 2007-06-04 11:32 AM (#61769)
Subject: Unusual tire wear on trailer?
I noticed yesterday after I got home from a barrel race, that the left front tire is worn more on the inside of the tire than on the outside. There is a lot of tred on the outside, but its getting smooth on the inside. What causes this? I have a 98 S&H 3 horse Contender and pull it with a 2003 Dodge 3/4 ton diesel.
flyinghfarm
Posted 2007-06-04 12:23 PM (#61773 - in reply to #61769)
Subject: RE: Unusual tire wear on trailer?
1000100100
if your wheel is tight and your hub is tight, my guess is a bent axle.  The camber (tilt) is wrong on the tire for some reason.  Good luck...maybe someone here is more able to diagnose that than I..
greyhorse
Reg. Nov 2005
Posted 2007-06-04 2:44 PM (#61781 - in reply to #61773)
I would guess that it's bent too, if there is a lot of slack in the bearings (they are worn out) that could possibly cause the problem too. I have an old trailer that does the same thing and it's a bent axle that causes the problem, it's just not worth replacing the axle on an old trailer that gets used so little.
Posted 2007-06-04 9:17 PM (#61802 - in reply to #61769)
The best solution is to seek out a heavy truck trailer shop with alignment capabilities.  They will be able to either align the axles or correct the bend.
My trailer was fixed that way.
