Waste tank repair
Last activity 2007-05-25 11:03 PM
1 replies, 3434 views
goods
Reg. Feb 2005
Posted 2007-05-25 8:16 PM (#61270)
Subject: Waste tank repair
My black water waste tank drain pipe is seperating from the tank. It is a black plastic tank and the drain pipe is black plastic. What can I use to seal it up and be strong enough to last several years?
Posted 2007-05-25 11:03 PM (#61274 - in reply to #61270)
Subject: RE: Waste tank repair
Unless the tank is Polyethelene, I've had good results roughing up the surface with coarse sandpaper and JB Weld epoxy smeared all over.
If it is Poly, use a hot melt glue gun. I would support the outlet because the hot melt isn't very strong structually
Edited by hosspuller 2007-05-25 11:06 PM
