Kodiak or Freightliner
Last activity 2007-05-06 11:09 PM
13 replies, 5914 views
hurley454
Posted 2007-05-02 4:21 PM (#60323)
Subject: Kodiak or Freightliner
 Could anyone tell me  what kind of luck they are having with a Kodiak  pulling a big trailer. I am not sure if i should lean toward a Kodiak or a Freightliner.
Covert Cowboy
Reg. Mar 2007
Posted 2007-05-02 4:25 PM (#60325 - in reply to #60323)
Subject: RE: Kodiak or Freightliner
Freightliner no question! All you have to do is look at the resale value of Freightliner versus Kodiak. That will answer all of your questions. There is no comparison.
PaintPony
Posted 2007-05-03 8:32 AM (#60350 - in reply to #60323)
I agree, the FL is heads and shoulders above the Kodiak...but it's also quite a bit more $. I have a Kodiak and it handles everything we hook it to with no problem...but....if there hadn't been such a significant difference in $ I'd have the FL instead. The Kodiaks are great trucks and are light years better than a dually for pulling and most importantly - stopping, but they are not on the same level as the FL. The Kodiaks are also known to be problem children, mine's been in and out of the shop SEVERAL times and it only has 32K on it. Most folks add performance chips or mods to them to get more power out of the motor and I think in a lot of cases that can lead to a lot of the problems they have with them (that was the case in my situation anyway). Check out the medium duty thread at www.thedieselplace.com for more info on the Kodiaks.
tpotts
Reg. May 2004
Posted 2007-05-03 9:23 AM (#60356 - in reply to #60323)
I just went through this same thing 3 months ago. I ended up with a used Freightliner. What sealed it for me was the fact that the Kodiak 4500 and 5500 had the same motor and transmission that my 3500 had.
Broken Bit
Posted 2007-05-04 7:42 AM (#60392 - in reply to #60323)
Freightshaker, without a doubt!  I pull the Bullrack with one everyday, been a good rig, not sayin' that I don't, sometimes wish it were a KW or Pete, but NEVER a Kodiak!  matter'n fact, it's about time to go fire that big kitty cat up for the day.  Talk to y'all later...
Covert Cowboy
Reg. Mar 2007
Posted 2007-05-04 8:36 AM (#60394 - in reply to #60323)
Didn't have much time to post the other day, but it looks like everyone else mirrored what I was going to say, anyway...
The Kodiak has the same engine and transmission as a one ton truck... the fit and finish of a Freightliner is light years ahead of a Kodiak... the Freightliner is going to last at least twice as long as the Kodiak. The medium duty engine in the Freightliner are million mile engines.
Tx. Vaquero
Reg. Jun 2006
Posted 2007-05-04 9:11 AM (#60400 - in reply to #60323)
Kodiak- more power, better braking, significantly quieter, only one available with 4 wheel drive, half the price. Sold a 2004.5 for $42,000 with 150,000 miles, paid $48,000 for it new. Check resale value of FL's on this site.
threeman
Posted 2007-05-04 12:18 PM (#60404 - in reply to #60323)
10010010025
If you do decide to go MDT (FL or Int, etc.) I suggest buying a used one. You can find one a year or so old for at least 30k less than new. Most of the 4500's I looked at over the last month new are 60 to 70k. i bought international 4400 for a tick over that with 6k miles.
Hey tx where you been? You go to W Monroe?
Covert Cowboy
Reg. Mar 2007
Posted 2007-05-04 12:37 PM (#60405 - in reply to #60323)
Te Kodiak has more power than a Freightliner? That's a good one! The standard engine on a Kodiak has 300hp and 650ft-lbs of torque. The Freightliner is 300hp and 860ft-lbs of torque... and I'm not even sure if Freightliner hasn't done away with that engine and made the 330hp/1000 the standard engine now as I've not seen a 300/860 for a long time.
None of that even matters, though. The Duramax is a LIGHT DUTY engine. The Mercedes is a MEDIUM DUTY engine. Pulling the same loads, the Freightliner is going to outlast the Kodiak in any situation.
Tx. Vaquero
Reg. Jun 2006
Posted 2007-05-04 1:12 PM (#60407 - in reply to #60404)
3man, congratulations on your international, they are great trucks. Glad you didn't end up with a valve spring breaking, valve swallowing, injector spitting Mercedes. I'll stick with this FREE LIGHT DUTY Duramax 500 hp/ 1000+ ft/lbs. for awhile. If it blows, I'll replace it and still have money left. I didn't go to LA., made Wildfire in Salado and Tex. championship in SA. then went to an invitational deal in Santa Fe.
threeman
Posted 2007-05-04 3:09 PM (#60413 - in reply to #60323)
10010010025
Yep I dont blame you at all on the truck deal.
What exactly was going on in LA? I saw it advertised but could not remember what it was.
Tx. Vaquero
Reg. Jun 2006
Posted 2007-05-04 3:13 PM (#60414 - in reply to #60413)
I thought you were asking if I went to the USTRC roping in W. Monroe and I just refered to it as La. I did not go, but heard it was plenty tough with a lot of teams.
threeman
Posted 2007-05-06 6:59 PM (#60478 - in reply to #60323)
10010010025
Just wondering what was going on in w monroe this past weekend. saw alot of trucks and trailers when eating there thursday night.
j
Too L Ranch
Reg. Jul 2006
Posted 2007-05-06 11:09 PM (#60491 - in reply to #60323)
Husband asked me that same question, a year ago. Champagne taste, beer budget. We got a Kodiak and it pulls, without any problems. We are in the Sierras, and don't have any problem with power on mountain roads. Been hauling the LQ, between a thousand and two thousand miles a month. We keep up with the routine maintenance, and no problems. Do carry an extra fuel filter, just in case (I have changed it on the side of the road, once). If money is no object, the FL is nice, but it sure isn't a necessity.
